Video Import Reference Freezing Frames #99170
Closed
opened 2022-06-25 18:55:57 +02:00 by Alex · 16 comments
Operating system: Windows-10-10.0.22000-SP0 64 Bits
Graphics card: Intel(R) UHD Graphics 620 Intel 4.5.0 - Build 27.20.100.8682
Broken: version: 3.1.2, branch: master, commit date: 2022-03-31 17:40, hash: cc66d1020c
When scrubbing through video reference there is times when a frame is frozen for one more frame. This delays the amount frames and goes out of sync with its audio. An example: Frame 1, Frame 2, Frame 2, Frame 3, Frame 4, Frame 4, Frame 5
Import an mp4 or mkv file as reference and scrub thorough the timeline to see
Childe Lost in Japan.blend
**System Information** Operating system: Windows-10-10.0.22000-SP0 64 Bits Graphics card: Intel(R) UHD Graphics 620 Intel 4.5.0 - Build 27.20.100.8682 **Blender Version** Broken: version: 3.1.2, branch: master, commit date: 2022-03-31 17:40, hash: `cc66d1020c` Worked: (newest version of Blender that worked as expected) **Short description of error** When scrubbing through video reference there is times when a frame is frozen for one more frame. This delays the amount frames and goes out of sync with its audio. An example: Frame 1, Frame 2, Frame 2, Frame 3, Frame 4, Frame 4, Frame 5 **Exact steps for others to reproduce the error** Import an mp4 or mkv file as reference and scrub thorough the timeline to see [Childe Lost in Japan.blend](https://archive.blender.org/developer/F13229358/Childe_Lost_in_Japan.blend)
Author
Added subscriber: @Nerodaboi
Author
Not sure what goes here
Member
Member
Member
Hi, hanks for the report. Steps for recreating the issue are not clear to me.
How you're adding video as a reference? From Add panel? {nav Add > Image > Reference}
Did you find this issue in other files as well or in attached file only?
Maybe a screen recording will help to demonstrate the actual problem.
Hi, hanks for the report. Steps for recreating the issue are not clear to me. How you're adding video as a reference? From Add panel? {nav Add > Image > Reference} > When scrubbing through video reference there is times when a frame is frozen for one more frame Did you find this issue in other files as well or in attached file only? Maybe a screen recording will help to demonstrate the actual problem.
Author
[Certain frames frozen.mp4](https://archive.blender.org/developer/F13234553/Certain_frames_frozen.mp4) [Frozen frames in 2D.mp4](https://archive.blender.org/developer/F13234552/Frozen_frames_in_2D.mp4) These are the videos
Member
Added subscriber: @mano-wii
Changed status from 'Needs Triage' to: 'Needs Developer To Reproduce'
I found a video that I could replicate the problem.
F13299578
Theoretically it is 30 fps (higher than 24 fps), so I don't understand why some frames are repeated.
Maybe it's a thing of the video itself.
I'm not sure if it really is a bug.
I found a video that I could replicate the problem. [F13299578](https://archive.blender.org/developer/F13299578/_091440_.mp4) Theoretically it is 30 fps (higher than 24 fps), so I don't understand why some frames are repeated. Maybe it's a thing of the video itself. I'm not sure if it really is a bug.
Added subscriber: @iss
Changed status from 'Needs Developer To Reproduce' to: 'Needs User Info'
Sorry for late reply here.
With video file from @mano-wii there is no issue. Even checking with ffmpeg tool ffmpeg -i #99170.mp4 test/out%d.png you can see there are duplicated frames encoded. But even then it is within codec capability to either duplicate frame, or simply not have any frame encoded where it is expected in which case old frame is displayed.
As of f0a3d2beb2, video playback is fetching video frames based on presentation timestamp, so there should be no synchronization issues as long as:
  • AV sync is enabled (in timeline playback popover menu, this is not enabled by default in General template)
  • Scene FPS matches movie FPS
@Nerodaboi please check if you meet these conditions. If you do, and you still have issues, please upload movie file.
Sorry for late reply here. With video file from @mano-wii there is no issue. Even checking with ffmpeg tool `ffmpeg -i #99170.mp4 test/out%d.png` you can see there are duplicated frames encoded. But even then it is within codec capability to either duplicate frame, or simply not have any frame encoded where it is expected in which case old frame is displayed. As of f0a3d2beb2, video playback is fetching video frames based on presentation timestamp, so there should be no synchronization issues as long as: - AV sync is enabled (in timeline playback popover menu, this is not enabled by default in General template) - Scene FPS matches movie FPS @Nerodaboi please check if you meet these conditions. If you do, and you still have issues, please upload movie file.
No activity for more than a week. As per the tracker policy we assume the issue is gone and can be closed. Thanks again for the report. If the problem persists please open a new report with the required information.
5 Participants
Reference: blender/blender#99170
