Loop Cuts and Inset Faces cutting Meshes #99219
2 Participants
Reference: blender/blender#99219
Operating system: Windows 10
Graphics card: NVIDIA GeForce GTX 750 TI
Broken: 3.2
Trying to add regular edge loops with Control + R, or even trying inset a face, they are cutting my mesh, or merging the ends. (I shared this on reddit, and it was suggested I create bug for it.
All I did was delete the bottom face of the mesh since I would not need it, but somehow I created invalid geometry and when I add an edge loop near the end it merges. If I try to inset the faces, it gives me weird end geometry.
(This is what was noted from someone on Reddit: Update: just checked the file and here are my findings:
Other things of note: the face orientation is inside out for this mesh (turning on Face Orientation in the Overlays menu (two overlapping circles in the header) shows them as red) and the object-level scale hasn't been applied. Fixing both of these doesn't correct any of the above issues -- although it IS normally advised since it prevents a few shading and modelling issues -- but it does, for some reason, change how the errors manifest, like the model collapsing in a slightly different way or the CTRL-R shortcut suddenly causing the same issues the tool version of loop cut and slide has.
Conclusion: you've somehow managed to turn this mesh into some form of invalid geometry that Blender can't seem to handle properly. You may wish to report it as a bug, including this file as a demonstration.
select visible face -> extrude + scale (will merge edges). Works with inset tool
Test File:
Issues Build2.blend
Added subscriber: @afaunce04
Hi, thanks for the report. If I understand correctly, the issue here is your object's geometry is broken after adding the loop cut. right?
But it's not clear how to replicate the bug from give n data.
As far as I can see you've already implemented this in your file. So what exactly I need to do further?
Also- Images you've attached and the model from the file are also different. Could you give us exact information for reproducing the problem?
The model in the file is correct. This larger cube is just a sample to show that it works fine on that. My actual little cube is the one that is the issue. Any time I inset faces or add loop cuts, it alters my geometry. I deleted it in my original file and just remade it, but it is doing the same thing. I am wondering if one of the BLENDER addons is causing this? I have Extra Objects on, Modifier Tools, Edit Mesh Tools, Loop Tools. I know by default these are turned off, so I am not sure if that is what is causing it.
You mean
Divider Planter
? Can repro in that case if I add loop cut orextrude+scale
along XZ planeSame happens in 2.93. Are you sure 3.0.0 is good version?
Yes that is the one! I am glad you were able to do it too. I also noticed, if I scaled down the bigger cube, and made it small like my original, it would also do the same thing. I would try to inset a face and it would completely alter my mesh, same for extruding and loop cut.
