Regression: Bones using Empties as Custom Shapes cannot be selected properly #99270
Closed
opened 2022-06-29 16:11:10 +02:00 by Christiaan Moleman · 17 comments
Operating system: Win 10 Home 64 bit
Graphics card: Nvidia Geforce 1050 Ti
Broken: 3.2
Worked: 3.1.2
Caused by 3267c91b4d
If you use an Empty instead of a Mesh (with the same shape) as the Custom Shape for a Bone, as of version 3.2 (and still in 3.3 alpha) the bone cannot be selected properly in Pose Mode.
Its selection hitbox seems to only cover the original shape of the bone instead of the shape of the Custom Object as you would expect, ie if you set a Cube empty as the custom shape you still have to click where the actual bone is to select it, instead of clicking on the edges of the Cube shape. If you use a Cube mesh instead of an Empty as the Custom Shape it behaves normally and you can select by clicking on the visible custom shape. In 3.1.2 it did not matter whether you used an Empty or a Mesh for the Custom Shape.
Steps to reproduce
**System Information** Operating system: Win 10 Home 64 bit Graphics card: Nvidia Geforce 1050 Ti **Blender Version** Broken: 3.2 Worked: 3.1.2 Caused by 3267c91b4d **Short description of error** If you use an **Empty** instead of a **Mesh** (with the same shape) as the **Custom Shape** for a Bone, as of version 3.2 (and still in 3.3 alpha) the bone cannot be selected properly in Pose Mode. Its selection hitbox seems to only cover the original shape of the bone instead of the shape of the Custom Object as you would expect, ie if you set a Cube empty as the custom shape you still have to click where the actual bone is to select it, instead of clicking on the edges of the Cube shape. If you use a Cube mesh instead of an Empty as the Custom Shape it behaves normally and you can select by clicking on the visible custom shape. In 3.1.2 it did not matter whether you used an Empty or a Mesh for the Custom Shape. **Steps to reproduce** - open .blend file - Try selecting bones where empties are used as custom shape [empty_vs_mesh_customshapes.blend](https://archive.blender.org/developer/F13238243/empty_vs_mesh_customshapes.blend) [emptyshape_bone_selection_01.mp4](https://archive.blender.org/developer/F13238248/emptyshape_bone_selection_01.mp4)
Added subscriber: @ChristiaanMoleman
#99708 was marked as duplicate of this issue
#99512 was marked as duplicate of this issue
Here is a scene I made to test this in isolation.
[empty_vs_mesh_customshapes.blend](https://archive.blender.org/developer/F13238243/empty_vs_mesh_customshapes.blend) Here is a scene I made to test this in isolation.
See this video for a demonstration:
See this video for a demonstration: [emptyshape_bone_selection_01.mp4](https://archive.blender.org/developer/F13238248/emptyshape_bone_selection_01.mp4)
Pratik Borhade changed title from Bones using Empties as Custom Shapes cannot be selected properly to Regression: Bones using Empties as Custom Shapes cannot be selected properly 2022-06-30 08:57:52 +02:00
Member
Member
Member
Added subscribers: @ideasman42, @lichtwerk
Member
CC @ideasman42
Caused by 3267c91b4d CC @ideasman42
Member
Well, there is no BoundingBox for empties, so I assume we gotta make a special dummy for empties in BKE_object_boundbox_get or just make an exception in pchan_culling_test_custom for empties (always returning true, thus always drawing them [for selection])?
Well, there is no BoundingBox for empties, so I assume we gotta make a special dummy for empties in `BKE_object_boundbox_get` or just make an exception in `pchan_culling_test_custom` for empties (always returning true, thus always drawing them [for selection])?
Member
Member
I have asked in #blender-coders:
would it be OK to give empties a boundingbox in BKE_object_boundbox_get based on their empty_display_size & empty_display_type? (boundingbox is used in viewport culling bones, ref. https://developer.blender.org/T99270 )
here the note from @JulianEisel :
I'd keep that separate from real, geometry based bounding boxes, so could be BKE_object_visual_boundbox_get()
I have asked in #blender-coders: > would it be OK to give empties a boundingbox in `BKE_object_boundbox_get` based on their `empty_display_size` & `empty_display_type`? (boundingbox is used in viewport culling bones, ref. https://developer.blender.org/T99270 ) here the note from @JulianEisel : > I'd keep that separate from real, geometry based bounding boxes, so could be BKE_object_visual_boundbox_get()
Campbell Barton self-assigned this 2022-07-06 12:19:02 +02:00
This issue was referenced by 7fb8e475d9
This issue was referenced by 7fb8e475d9eca93bff87f011b29ac8aa7bc0ebca
This issue was referenced by 34c701abbd
This issue was referenced by 34c701abbdbfa6143c11e1b6f8d7797257c70237
Member
Added subscribers: @shadow_creeper, @OmarEmaraDev
Member
Added subscriber: @Mustard
6 Participants
Reference: blender/blender#99270
