Outliner: Double click on icon to select contents/hierachy #99275
18 Participants
Reference: blender/blender#99275
Motivation
Users often want to select all objects in a collection, or all (direct or indirect) children of an object to transform them together, or apply different operations. For this, the Outliner context menu already provides Select Objects when right-clicking on a collection, and Select Hierarchy when right-clicking on an object. Since these are such common/useful operations, faster access would be a good quality of life improvement.
Note that both cases are an operation acting on the entire hierarchy, so they are recursive. With the difference that the first doesn't keep the clicked on element selected, while the second does. Other than that these are consistent operations.
Corner Cases to Consider
Implementation Notes
ED_outliner_select_sync_from_outliner()
. If done the other way around (object is selected and outliner tree is synced from that), all occurrences would be selected in the Outliner. This is what the existing Select Objects and Select Hierachy do, and it's a bit tricky to correct that.Added subscribers: @JulianEisel, @JulienKaspar
Added subscriber: @dominikfill
Added subscriber: @1D_Inc
Nice topic. A couple of questions though:
Does it consider the way for multiple items selecting?
Maybe something like Shift+doubleclick?
How about deselecting? (I want the entire scene selected except those two collections I organized especially to filter out)
Maybe something like Alt+doubleclick? (Shift+doubleclick the second time to deselect already selected probably will
be hard to handle, since it will depend on selected conditions, especially if collection is collapsed)
Will there be chaining action? Will it select the entire hierarchical branch of collections of a doubleclicked collection (aka "nested collections")?
Maybe something like Ctrl+Shift+doubleclick?
Also what about conventional doubleclick renaming, used everywhere (from os to softwares)?
Will it be optional or will influence only icon doubleclicking, not name text box doubleclicking?
This will result in weak selection indication (one of the reasons it was decided to solve selection as a separate icon with multiple states in Collection Manager addon).
Probably, not critical, but not pleasant either.
A slightly offtop:
Does it have any shorter official term?
We call this property as "cumulativity" during discussing system design at local level (for example, collection engine paradigm can be described as a "common layer paradigm - aka /photoshop layers/ - but with cumulativity". Cumulative objects, Cumulative collections and Collections with cumulative objects usually require additional handling as any other cross-hierarchical structures), but most of time at global level it is just called "when objects or collections are linked into multiple collections" each time and it seems to be quite a long term for official feature.
Added subscriber: @pablovazquez
I think it will speed up workflow immensely, it's worth trying.
That could work.
The operator should only run when double-clicking on the icon. Double-click on the item's name to rename should stay as it is the way it's been since forever and it's even the only way to rename in some areas (e.g. UI Lists such as Vertex Groups).
The weak selection indication for collapsed Collections issue is already present before this patch, this change does not affect it.
If tests show that it's too unclear we could go for something similar to the highlight for active items, but using the color for selected objects in the Outliner/Viewport (quick mockup).
{F13239953, size=full}
Sweet.
Thank you for the answer.
Added subscriber: @BClark
Yes, I have to select by hierarchy through the menu way too often, I would love to have a better select all in collection action.
Added subscriber: @msal
Added subscriber: @mgradysaunders
I thought this seemed like a great feature and reasonable first project, so I'm taking a crack at implementing it. I think I have things working as intended, minus the corner case (looking into that now). The diff is at https://developer.blender.org/D15351. Here's a quick demo. Feedback is welcome and appreciated.
demo.mp4
Added subscriber: @AndyCuccaro
Added subscriber: @Slowwkidd
Added subscriber: @Mangal-Kushwah
Added subscriber: @santbg
You might consider that a single click on the icon selects everything in the Collection, and to deselect click on the empty space.
Unless there are any drawbacks it is more intuitive and has no hidden hacks or shortcuts.
At least at first glance, I think @santbg's single-click solution could tidy up the design and implementation a bit. Per the description in the diff, deselect currently works by CTRL+ALT+double-click on the icon, where the ALT is necessary to disambiguate it from an ordinary CTRL+single-click to deselect. If we just used the icon itself to distinguish whether the user wanted recursive selection, then both selection and deselection should work consistently with ordinary CTRL+single-click behavior.
Of course, there may be drawbacks I'm not considering. But I'm happy to update the diff if given the go ahead.
Then you will select collection's content instead of collection in case of missclicking, for example, when you need to move collections in the outliner.
Doubleclick prevents from this, separating selecting collection from selecting its content during fast work.
On twitter I saw that they created a new operator, in which you can assign the shortcut you want.
I don't know if it's someone from here.
https://twitter.com/CosmoMidias/status/1544498062907047936?s=20&t=4RsDLCxjwwjmVQwWEeFX8g
After a meeting with @JulianEisel, we agreed that double-click is the way to go. Single-click is used to change context in the Properties editor, which is super handy, but more importantly it's also used to make a Collection active (without affecting selection).
Regarding modifiers, we should follow as close as possible what it's already there.
The same goes for deselecting.
Here is a quick video explaining it (with audio, at 1:01 I said Ctrl when I meant Shift):
sc_-2022-07-12_17.20.04.mp4
Another reason to avoid single clicking is that it's easy to accidentally single click on the icon, so the hierarchy would be selected rather than the single element. When the collection is collapsed there's no way to see the difference in the Outliner.
Implementation wise, I think it's fine to first get the basic logic for selecting the hierarchies ready, and then in a separate patch making that work with {key Shift} and {key Ctrl}. Otherwise it might be a bit too much to take on at once :) Of course the first patch should be designed so the second doesn't have to completely rewrite the logic again.
Having read the specs laid out by Julian and Pablo, I've revised my diff for this task. I'll update with arcanist momentarily, after I clean things up a little. But here is a quick demo (now with voiceover) new-demo.mp4
Hm.
I am not agree with the original Ctrl and Shift selection assignment in the outliner - it was assigned in the way it contradicts to the rest of Blender, and probably should be swapped.
For example,
which is reasonable since Shift is a better accessible key than Ctrl, so it better fits more relevant operation (such as adding items to a selection) rather than less relevant operation (such as selecting a range).
Example1: Shift+LMB is used for adding/removing several individual Object transforms to a selection (adding/removing curve points also is a Shift+LMB action), and Ctrl+LMB selects curve points in a range between the beginning and current position of a cursor,
Example2: in edit mode Shift adds/removes individual vertices to a selection, and Ctrl is used for range selection (Pick Shortest Path operator)
The outliner and file/asset managers seems to be the only editors where Shift and Ctrl functionality is swapped.
I guess we reached the point it should be addressed, otherwise the outliner behaviour differentiation from the rest of a program will keep spread its inconsistency as its functionality will grow.
How do you think?
@1D_Inc I agree but I think for the sake of this task we can ignore this inconsistency. If the keys are swapped or not doesn't affect the functionality of this design, and merely follows existing design decisions.
I'd propose to have a separate discussion about the Shift and Ctrl key assignments.
Okay. Indeed, even if it is tightly connected, in general it is a different topic that require different level of arguments.
A very nice demo.
However, at some point it is highly recommended to create a scene that contains all the functional possibilities and flexibilities - including cumulative objects, cumulative/nesting/linked collections, and so one, for proper testing purposes.
When we was testing our selection tools, we created several scenes for such kind of purposes, to make sure our concept works with the most of possible cases correctly.
Noted, thanks. Do you happen to have a feature complete scene from a previous effort lying around for testing? I think I have the bases covered but there is a chance of a sneaky or advanced feature I'm not too familiar with breaking things.
As a quick sanity check, I just fired up blender, created another collection with a new Suzanne, then added a linked duplicate of that collection under the default collection, and also added a normal duplicate of the that collection with a parent relationship crossing between collections. The CTRL/SHIFT functionality seems to behave as expected, with nesting and either open or closed sub-objects. I'll record another video when I get a minute.
Side note: I managed to wire things up exclusively on the "layer level" as per the usual range select, i.e., working only in terms of flagging layers for selection so that everything gets picked up by the sync function later, thus bypassing the original logic used to implement the right-click versions of these. That is to say that there shouldn't many distinct code paths where things can go horribly wrong. But again I'm new, etc.
Yes, here is one of those scenes we used to check overall practical collection engine setup readability and functional/navigational completeness, that's why it is more complex than basic generic setup.
https://dropmefiles.com/U727N (the link expires in a week)
Objects that represents cross-hierarchical things are created as a text objects for a better structural clarity and visual control.
Thanks! I spent some time testing things out this morning. Overall the behavior is sensible, but there's a couple things I want to demonstrate and verify. See the following video.
new-demo-2.mp4
Added subscriber: @JanErik
@mgradysaunders
This looks so nice! Very well done and extremely helpful. I think the recursion can stop at object level, data/materials is not needed
Thank you. And I'm guessing the behavior of stopping at the object level will be the consensus opinion. Went ahead and updated the diff with that change 👍
Nice video!
2:12 - Yes, those elements are supposed to be selected like that, since they are cumulative and belong the first collection as well, so selecting this collection will also select those objects.
2:57 - About Ctrl deselection, can you show what will happen if to deselect both collections - will cumulative objects remain selected after that (we faced such kind of an issue before, so it is interesting to look at the result)
Apologies for the radio silence, was out and about over the weekend. To address @1D_Inc's question, here is one more demo which also shows the stop-at-object-level functionality.
new-demo-3.mp4
No worries, there are no deadlines in such kind of tasks anyway)
Hierarchical functionality can ve solved only at the moment they solved.
Wow, it seems you nailed cumulative elements deselection!
That is spectacular and respectable.
How did you achieved that, by the way?
Do you control if the deselected instances are last in the selection somehow?
Thank you! I figure can't take too much credit, as the idea and implementation turn out to be rather simple. In other words, it hasn't been necessary to handle cumulative objects with any specialized code or anything. Here is main routine.
This only needs to be called in a place or two, configured according to the double-click and modifier keys. Then the actual selection of objects in the scene gets synchronized to the outliner via
. Not sure what the historical bug was, but I might guess it was fixed somewhere in this routine? -- which I have not needed to modify 👍Indeed, seems to be solved with quite generic recursion. Feels strange though.
Nice job anyway)
Very functional.
Even though I still think that selecting the hierarchy with just 1 click on the whole item (icon + name), and not just the icon would be even more intuitive, this is a huge improvement in usability, so congrats! I wanted to ask if this will be also shown as an operator in the Outliner keymap preferences, giving the user the possibility to e.g. change from dbl-click to single click?
Added subscriber: @jc4d
Agree with you about having a preference for it. Suffering of carpal tunnels, double clicks are more difficult to perform and creates more restrain than singe click.
is there a chance, that this feature will be part of 3.3 ?
I'll see if I can figure this out. There is just 1 slight complication (with event filtering being necessary on the first click for CTRL/SHIFT clicks on icons). But I should be able to work around that, conditional on whether single clicking is set in preferences.
I think the diff is in a good place, and it is only ~100 line change. But that said, I have no power around here (can't merge), so the code will still need to be code-reviewed and merged by somebody else.
It is not clear how will you reorder/manupulate nested collections in the outliner if a single click selects a hierarchy rather than individual elements.
However, we also faced with singleclick demand during Collection Manager addon design.
I mean - the need for "quickly individually view the contents of collections, selecting them through with a single click to understand what is where in a scene", so we decided to
assign Ctrl+LMB action to non-chaining resetting collection selection for that purpose (when selection of a collection resets existing selection, selecting only items that belongs to the first level of a collection)
instead of additive that we decided to assign to Ctrl+Shift+LMB (when selection of a collection adds/removes collection's nesting elements to a selection similar to the way it is made there).
But CM is an addon and its collection list is separate to separate collection navigation mechanics from object/general navigation mechanics presented in the outliner, so it can afford such design flexibility...
Outliner is an outliner, and it is supposed to support outliner's functionality first.
Added subscriber: @CosmoMidias
Hello, @santbg! That was me experimenting with the bult-in operators trough the keymap. Turns out that you can customize a lot, listen to double clicks and also pre define some options for an operator when invoked. But here we see the developers actually implementing some of those quality of life improvement in a much more robust and complete way. Super happy to see it happening!
Glad to see this taking shape! Thank you!
There is one little suggestion I'd like to request:
when extending the selection with SHIFT key could we have it implemented in a way that the last selected click make the target active instead of keeping the first as the active? I think this would be more consistent with other areas in Blender (set active on last click). What you guys think?
Sounds interesting, but what for you need the active in cases when you have range selection?
It seems it already moves collections like that, so 1 click selection can be actually useful. For example, it will allow to check in the viewport what objects you operate with.
I was looking for reference on how other systems work and C4D works with 1 click to select everything in a hierarchy.
🫣 Don't judge me just looking for reference to clarify an idea.
The reason is we usually plan to perform other operations after a group of objects are selected. For example Linking the Materials from the active object or copying selected modifiers from the active.
Currently after a range selection, I have then to hold CTRL, to deselect the object I want to make active, keep holding CTRL them selecting it again. Now it’s active and now I can perform the next operator that takes in account the active selection.
Or I have to beforehand remember that the outliner does not work like the other areas of Blender an start from the object I want to be active. And I usually fail in remember that because the muscle memory comes stronger from 3D view object selection and edit mode.
I’m sorry if this falls out of the scope of this patch but at first I thought it could be requested here. Thanks for working on that. - J.
The problem is that layers system in C4D is not cumulative.
In Blender if you will select a collection which contain object located in other collections as well, it is not very clean how to rearrange such collection keeping cumulative object's instances in their original places.
It can be tricky to solve and even solved can be mind messing.
It require a good luck to have an object that is needed to be active, placed in the beginning or in the end of a desired range.
Such case is not very common, don't you think?
There are two strategies in active object paradigm.
I think, current outliner's solution represents the same mechanics - you can pick one by one (in this case active will be the last), and you can pick active and expand the selection (in this case the active remains first).
I also think that it has another useful aspect - you can pick active in the viewport, then locate it in the outliner with num. (which is quite common situation), and expand the selection with ctrl+shift, keeping active for the desired operation.
I should spend some time playing with the outliner now in a different mindset/expectation and feel it working. I think your points make sense. ✨👌🏽
edit: I was wrong about that. Sorry for the inconvenience and thank you for the heads up.
Since we'll soon already enter bcon2, can we hope to see this beauty for 3.4?
Still not entirely sure how/when the development phases kick off, but I hope so. I went ahead and caught up the diff with master. After rebuilding, the behavior still works as shown in the videos. If there is anything else I can do, let me know.
Would be really great, if this feature would finally land in master
Added subscriber: @Nico-Traber
@mgradysaunders Hey! Do you think you'd have time for this sometime soon? Blender 3.6 is still in Bcon1, it'd be great to bring this one back to life (at least to get the patch updated to the latest
main
and over to projects.blender.org). I can help testing and I bet many others in the community as well. Thanks!It's a pity the development of this stopped, it's a much needed feature that a lot of people would welcome. Can we hope for 4.0?
Hey @mgradysaunders would you have time to work on this for 4.0? Or it'd be better taken over by someone else? Thanks!
@pablovazquez I can try to take a look at this again. And sorry I apparently missed the notification from March 6.
I will clarify that this is the first thing I have ever tried to contribute here and I have no idea what I'm doing in terms of Blender development workflows or phases or versions, etc. The activity on the thread was a little hit or miss, and I wasn't sure when or how this would be able to be merged so I ended up just kinda forgetting about it for a while.
But anyway the overall code changes here are pretty small. I'll try to get my Blender build up to date later today, hopefully without any conflicts from other code changes that have been incorporated in the meantime.
Looks like Blender has switched Git URLs entirely in the meantime. So it might take me a minute to get back to where I was with this, but hopefully not too long. I'm going to see if it is possible to transfer the diff over to my new clone. But it should be ok even if that doesn't work. Getting this to where it was at the beginning on the thread only took a couple days of hacking, and that was mostly me trying to decipher how the existing code was already working.
And I appreciate your enthusiasm @Slowwkidd, hopefully one day you will actually be able to use this feature.
Thanks for coming back to this! A lot has changed indeed since then. We moved to this new platform, new Git URLs should be easy to change though in your git config. Some files may have been moved to C++ too, sometimes I find it easier to just rewrite the patch especially if it only affects a few files, may even come up with new ideas on how to tackle the issue.
Hope you still have the energy to look into this, such a valuable feature and hopefully paves the way for other (much needed) improvements in the area.
I have the patch reimplemented the way it was working before without issue.
However, I realized that there is one more corner case that may not be working as desired, in particular when an object has a child from another collection. Referring back to the "corner cases" at the top of thread, it seems that the desired behavior is that, if I double click a collection icon, then we recurse into and select all collections and objects, but if we end up at the child of an object that actually belongs to another collection, then do not select or recurse into that child.
It doesn't work like that just yet, but it shouldn't be too hard to figure it out.
Yes, since cumulativity assumes cross-hierarchical structures, it creates different corner cases that are challenging to predict on a fly but need to be taken care of.
As a result, collection development (and using) requires a deeper involvement than its counterparts.
Just checking in to say that I haven't gone off and completely forgotten about this again. I had some PTO from my regular job, and then spent some time getting more of my development environment set up on a new computer. All of that is taken care of at this point, so I will hopefully have some updates soon.
Thanks for the update! Looking forward to have this in 4.0.
@msal hi, whenever you'll submit a new PR, make sure to submit it without the changes I had requested: https://archive.blender.org/developer/D15351
You can later commit them separately once PR is created.
Also: Things might have changed by now due to ongoing outliner tree refactoring
I think I have the desired behavior wired up. The invariant condition is "recursive selection does not cross collection boundaries" in plain English. In other words, we recurse into parent/child object hierarchies, but only recurse into the children which are part of the same collection as the parent object. And I believe I have consistent behavior for extended selections working as well. I'll record a demo sometime soon, and I'll also see about that outliner tree refactoring thread. Haven't looked into it yet, but even if it tramples the way this is implemented, the diff is only +143/-14 at the moment.
Here is my update/demo, finally. Not sure if the uploaded file will automatically appear or if I have to link it so here is the link:
This should demonstrate the usage and thought process decently well. Let me know if you have any objections.
Also since my post last week, I saw that the most recent wave of changes from the possibly conflicting outline-tree-refactoring luckily had no conflicts at all with my local diff, so we should be good on that front. I'm going to convert all of this into a new fork/pull-request later this evening and I'll update with the link when I have it.
I just realized I was straight up wrong about Blender being on GitHub. Woops. I was on https://projects.blender.org/blender/blender and thought it was a GitHub page. Anyway, the fork/pull thing seems to be the same. Working on setting it up now.
Ok, here is the PR: #110151
Interesting video.
Not sure about Shift+doubleclick solution. The problem is that UX-wise doubleclicks misclicking are usually hard to distinguish in cases when the result is not obvious (for example, in long outliners with lots of objects) because of a low visual feedback level.
But the presented functionality of a range selection is interesting, so I doubt whether it should be assigned by default to shift + click instead of shift + double click.
To me the mental models seems perfect and the implementation exactly what is required 👍
@1D_Inc All recursive selection operations that were shown should stay a double click on icons for consistency imo. If not, then all of them should be on single click on icons instead.
Going for a single click is easier to discover but also easier to execute by accident, because it then only relies on whether you click on the icon or name of an item.
If executing these by accident is the core issue, then there should also be better undo support in the outliner. Outliner selection states are not remembered in undo atm.
The provided functionality looks great.
But we usually give a tests to interactions behaviour in order to make sure how exactly we will make missclicks, it is hard to say on a fly.
Undo solution is not applicable in general when the result of a missclick is not detectable.
It seemed to me that ctrl+shift was mentioned in the video, but it wasnt displayed. Am I wrong?
That is a good point @1D_Inc, I should have been clearer about that.
I only showed Shift double clicking in the video. Ctrl double clicking instead has the same effect of "growing" or "extending" the selection, but without trying to "fill in" the selection between the active layer and the interacted-with layer. So you disparately piece your selection together as in the usual case of Ctrl single clicking.
Ctrl+Shift at the same time doesn't do anything, at least not at the moment.
And I could see how misclicking could pose a minor UX nuisance. It is worth noting that Ctrl or Shift single-clicks on icons are ignored as part of the event filtering because it is the only practical way I could find to disambiguate the double-click from everything else you could do when single or double clicking elsewhere in the box. Plain single-clicks on icons work as before. I can try to look at this again, but there is a bit of conundrum with who-handles-what-first.
In any case, there is already a slight visual indicator for interacting with icons, but it would probably be helpful to exaggerate that somehow as part of introducing this double-click behavior.
Will this useful feature finally make it this time? The time frame for 4.0 is closing soon I guess.
I thought about interoperability solutions for a while, and has come to conclusion that doubleclick is a nice mechanics for selecting a single collection, since such an action is imperative, but for multiple collections a declarative way of a selection could be a better way
Such as - select multiple collections headers, then press a button, say, L key, for expanding selection to their objects content. This will allow to avoid missclicks during struggling with multiple doubleclicks.
Deselecting (for example when you need to select all the collections of a scene except two) could be done in the same way - selecting everything in the outliner, deselecting two collection's headers and pressing L for expanding selection to selected headers only.
How do you think?
This is possible solution for static context selection solution (operating with names in outliner), we also designed a dynamic context selection solution (for collections data handling directly in the viewport)
Dynamic context solution is technically an offtop here, but if it is interesting I can make a short descriptive video about such an approach to this problem.
Any updates on the progress? This is such an immensely useful feature.
796577d76e
is merged so I think this can be closed now 🙂
