Length parameterization failure case #99370
Closed
opened 2022-07-04 03:38:34 +02:00 by Hans Goudey · 5 comments
Member
ab444a80a2 recently improved the length parameterization used for sampling curves.
However, the logic may have an issue, the following test causes an assert:
TEST(length_parameterize, SampleZero)
  Array<float> values{{2.08131456f}};
  Array<float> lengths = calculate_lengths(values.as_span(), false);
  Array<float> sample_lengths{{0.0f}};
  Array<int> indices(1);
  Array<float> factors(1);
  sample_at_lengths(lengths, sample_lengths, indices, factors);
  Array<float> results(1);
  linear_interpolation<float>(values, indices, factors, results);
  Array<float> expected({{0.0f}});
  for (const int i : results.index_range()) {
    EXPECT_NEAR(results[i], expected[i], 1e-5);
Sampling a length of zero should return an index of zero and a factor of zero.
My hunch is that using upper_bound instead of lower_bound doesn't cover some
edge cases that aren't properly tested yet. I remember making that switch when coding
two previous versions of this algorithm.
Something like this might work (the code below still has some mistake though).
  const float *offset = std::lower_bound(lengths.begin(), lengths.end(), sample_length);
  const int prev_point_index = std::max<int>(offset - lengths.data() - 1, 0);
  const float segment_start = lengths[prev_point_index];
  const float segment_end = lengths[prev_point_index + 1];
  const float segment_length = segment_end - segment_start;
  const float length_in_segment = sample_length - segment_start;
  const float segment_length_inv = math::safe_divide(1.0f, segment_length);
  const float factor = length_in_segment * segment_length_inv;
ab444a80a2 recently improved the length parameterization used for sampling curves. However, the logic may have an issue, the following test causes an assert: ``` TEST(length_parameterize, SampleZero) { Array<float> values{{2.08131456f}}; Array<float> lengths = calculate_lengths(values.as_span(), false); Array<float> sample_lengths{{0.0f}}; Array<int> indices(1); Array<float> factors(1); sample_at_lengths(lengths, sample_lengths, indices, factors); Array<float> results(1); linear_interpolation<float>(values, indices, factors, results); Array<float> expected({{0.0f}}); for (const int i : results.index_range()) { EXPECT_NEAR(results[i], expected[i], 1e-5); } } ``` Sampling a length of zero should return an index of zero and a factor of zero. My hunch is that using `upper_bound` instead of `lower_bound` doesn't cover some edge cases that aren't properly tested yet. I remember making that switch when coding two previous versions of this algorithm. Something like this might work (the code below still has some mistake though). ``` const float *offset = std::lower_bound(lengths.begin(), lengths.end(), sample_length); const int prev_point_index = std::max<int>(offset - lengths.data() - 1, 0); const float segment_start = lengths[prev_point_index]; const float segment_end = lengths[prev_point_index + 1]; const float segment_length = segment_end - segment_start; const float length_in_segment = sample_length - segment_start; const float segment_length_inv = math::safe_divide(1.0f, segment_length); const float factor = length_in_segment * segment_length_inv; ```
Author
Member
Author
Member
Hans Goudey changed title from Length parameterization errors to Length parameterization failure case 2022-07-04 04:13:32 +02:00
Member
Author
Member
Author
Member
The code that ended up working was this:
  const int prev_point_index = offset - lengths.data();
  const int next_point_index = prev_point_index + 1;
  const float segment_start = (prev_point_index == 0) ? 0.0f : lengths[prev_point_index - 1];
  const float segment_end = lengths[next_point_index - 1];
But now I can't reproduce the original error, and the sample curve node is working fine in my tests, so I'll just close this.
The code that ended up working was this: ``` const float *offset = std::lower_bound(lengths.begin(), lengths.end(), sample_length); const int prev_point_index = offset - lengths.data(); const int next_point_index = prev_point_index + 1; const float segment_start = (prev_point_index == 0) ? 0.0f : lengths[prev_point_index - 1]; const float segment_end = lengths[next_point_index - 1]; const float segment_length = segment_end - segment_start; const float segment_length_inv = math::safe_divide(1.0f, segment_length); const float length_in_segment = sample_length - segment_start; const float factor = length_in_segment * segment_length_inv; ``` But now I can't reproduce the original error, and the sample curve node is working fine in my tests, so I'll just close this.
2 Participants
Reference: blender/blender#99370
