picker isn't working on cryptomatte matte id picker #99445
Open
opened 2022-07-04 21:51:35 +02:00 by michael campbell · 8 comments
Operating system: Windows-10-10.0.19044-SP0 64 Bits
Graphics card: NVIDIA GeForce GTX 1070/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 512.96
Broken: version: 3.3.0 Alpha, branch: master, commit date: 2022-06-27 22:46, hash: 7a44f62bdb
add a cryptomatte node (new or legacy), hover over matt id and press E . No picker will appear meaning user must click the + icon.
**System Information** Operating system: Windows-10-10.0.19044-SP0 64 Bits Graphics card: NVIDIA GeForce GTX 1070/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 512.96 **Blender Version** Broken: version: 3.3.0 Alpha, branch: master, commit date: 2022-06-27 22:46, hash: `7a44f62bdb` Worked: (newest version of Blender that worked as expected) add a cryptomatte node (new or legacy), hover over matt id and press E . No picker will appear meaning user must click the + icon. ![image.png](https://archive.blender.org/developer/F13258856/image.png)
Added subscriber: @3di
Member
Member
Member
Thanks for the report. Shortcut only works when hovering over +/- icons
Different problem, but may be related to #101058
Sergey Sharybin added
and removed
labels 2023-02-15 17:53:30 +01:00
Does not seem to be related. This report is about eyedropper not starting at all and the #101058 is about eyedropper not properly picking up matte id.
As for this report, the way how the cryptomatte eyedropper is implementes is quite horrible and can not support text fields. We need to move it out of the generic eyedropper, which will remove some internal tricketry with invisible properties, as well as will allow using eyedropper from the field itself.
Does not seem to be related. This report is about eyedropper not starting at all and the #101058 is about eyedropper not properly picking up matte id. As for this report, the way how the cryptomatte eyedropper is implementes is quite horrible and can not support text fields. We need to move it out of the generic eyedropper, which will remove some internal tricketry with invisible properties, as well as will allow using eyedropper from the field itself.
Member
I'd consider this a known limitation, using the eyedropper from the main text button isn't supported.
Problem is that the cryptomatte eyedropper reuses the color eyedropper operator, this is kind of a hack. It doesn't seem difficult to add a separate eyedropper operator. We also have data-block, driver and depth eyedropper operators for example. The button could then even display the eyedropper icon we show in other places (at least when there's no value set yet):
Design wise there is the question how this should work though: Does it always add? Or does it replace? Or can you for example hold Alt while clicking to toggle from add to remove? Sounds like straight forward design decisions though.
I'd consider this a known limitation, using the eyedropper from the main text button isn't supported. Problem is that the cryptomatte eyedropper reuses the color eyedropper operator, this is kind of a hack. It doesn't seem difficult to add a separate eyedropper operator. We also have data-block, driver and depth eyedropper operators for example. The button could then even display the eyedropper icon we show in other places (at least when there's no value set yet): ![](/attachments/1672b60b-2ff6-45b7-b1ff-9e56128dfe2b) Design wise there is the question how this should work though: Does it always add? Or does it replace? Or can you for example hold Alt while clicking to toggle from add to remove? Sounds like straight forward design decisions though.
@JulianEisel I think we should try to implement the feautre properly. It is kinda a bug from expectation point of view -- it doesn't work the same as, for example, bones selection where you can click "E" on the entire field.
I'd give it a try, and only move to known limitation if some big design limitation is encountered.
As for the behavior: doesn't seem like a complicated decision to be made either :)
@JulianEisel I think we should try to implement the feautre properly. It is kinda a bug from expectation point of view -- it doesn't work the same as, for example, bones selection where you can click "E" on the entire field. I'd give it a try, and only move to known limitation if some big design limitation is encountered. As for the behavior: doesn't seem like a complicated decision to be made either :)
5 Participants
Reference: blender/blender#99445
