Regression: Subdivide Curve node functions incorrectly when operating on certain outputs of a Mesh to Curve node #99648
5 Participants
Reference: blender/blender#99648
Operating system: Windows-10-10.0.19044-SP0 64 Bits
Graphics card: Quadro K3100M/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 426.78
Broken: version: 3.3.0 Alpha, branch: master, commit date: 2022-07-11 17:16, hash:
2a1d12d7a0
Worked: 3.2.1
Caused by
9435ee8c65
When using the Mesh to Curve node on a mesh with vertices that have more than two connected edges, the resulting geometry is not properly handled by the Subdivide Curve node. Some curve control points located at such vertices have their positions reset to the origin. The bug did not occur when I tested it with a curve whose control points shared the same position for other reasons.
I suspect this is likely related to #95443
See attached .blend file:
Mesh To Curve Subdivide Bug.blend
Added subscriber: @AgentA1cr
Added subscriber: @Leo-Luther
I can confirm this behavior, yet it is not due to how many edges were connected to a point or points sharing positions, or due to the mesh to curves at all.
The issue comes up if your curve object (whether created via mesh to curve or not) has more than 1 spline.
The index of the endpoints seems to get messed up and they "loose" their position (get set to (0|0|0))
Subdivide Curve node functions incorrectly when operating on certain outputs of a Mesh to Curve nodeto Regression: Subdivide Curve node functions incorrectly when operating on certain outputs of a Mesh to Curve nodeAdded subscribers: @HooglyBoogly, @PratikPB2123
yes, caused by {9435ee8c65193e3d4af8f1ac5b07b7884cf62bd5}
cc @HooglyBoogly
I want to reiterate that it does not seem to be due to the mesh to curve, but it is a general issue with the subdivide curves node on all poly splines (more than one spline).
If you mesh to curve and then change the spline type to anything other than "poly" before subdividing, it will work fine.
The subdivision will also not work correctly using multiple "regularly" created poly splines (mesh line e.g.)
Seems to also be happening on more than one NURBS curves
Added subscriber: @mod_moder
I tried to research this question. So far, I've only noticed that point offsets are written using an always empty mask. But fixing that didn't fix things much. Although, if there are other problems, then the 0th offset still united
I'm fairly certain this is resolved with recent fixes to the subdivide node. If it's not, we can reopen this task. Thanks for the report.
