Encoding with DNxHD fails due to bad parameters #100079
Reference: blender/blender#100079
Steps to reproduce:
Looks like
constant_rate_factor
is set toFFM_CRF_MEDIUM
, which shouldn't happen for DNxHD codecs, as it causescrf
to be set in the FFMPEG options.Original Report
Operating system: Windows 10 19044.1826
Graphics card: GTX 1070
Broken: 3.4.0 alpha master
9b9417b661
(also tested on 3.2.1 mastera2d59b2dac
so this isn't a bug with introduced in alpha)Worked: wasn't able to find a working version
DNxHD rendering doesn't normally work, but I was able to get one file working somehow. Both attached files should have exact same settings, but only one renders. When the render fails with the broken file, it gives the
ff_frame_thread_encoder_init failed
error, and with --debug-ffmpeg, video parameters are incompatible with DNxHD. Notably however both files print the same video parameters to the console:Exact steps for others to reproduce the error
Try rendering both files. With the working file, I have previously used a DNxHD file in sequencer and rendered it as H264 lossless, however I wasn't able to reproduce a working file with this. The broken file is a default file, with a video file in sequencer, and the render output settings changed to DNxHD.
system-info.txt
DNxHD broken.blend
DNxHD works.blend
Added subscriber: @Juuso-Laine
Added subscriber: @OmarEmaraDev
Looks like
, which shouldn't happen forDNxHD
to be set in the FFMPEG options.Strange DNxHD bug, one blend file renders but other doesn't with exact same settingsto Encoding with DNxHD fails due to bad parametersThis issue was referenced by
06a01168f6
Note for fix, to observe effect, set codec to different one and back to DNxHD.
