Add on mtree #100150
Closed
opened 2022-08-02 18:51:02 +02:00 by Anirban Das · 4 comments
Operating system:
Graphics card:
Broken:
(example: 2.79b release)
**System Information** Operating system: Graphics card: **Blender Version** Broken: (example: 2.79b release) (example: 2.80, edbf15d3c044, blender2.8, 2018-11-28, as found on the splash screen) Worked: (optional) **Short description of error** **Exact steps for others to reproduce the error** Based on the default startup or an attached .blend file (as simple as possible).
Author
Added subscriber: @Anirban31
Added subscriber: @iss
This report does not contain all the requested information, which is required for us to investigate the issue.
Please submit a new report and carefully follow the instructions. Be sure to provide system information, Blender version, the last Blender version which worked, and a .blend file with exact steps to reproduce the problem.
A guideline for making a good bug report can be found at https://wiki.blender.org/wiki/Process/Bug_Reports
This report does not contain all the requested information, which is required for us to investigate the issue. Please submit a new report and carefully follow the instructions. Be sure to provide system information, Blender version, the last Blender version which worked, and a .blend file with exact steps to reproduce the problem. A guideline for making a good bug report can be found at https://wiki.blender.org/wiki/Process/Bug_Reports
2 Participants
Reference: blender/blender-addons#100150
