Diffuse Light pass not working as expected in 3.2 Eevee with 'shader to RGB' #100166
Reference: blender/blender#100166
Operating system: macOS-12.4-x86_64-i386-64bit 64 Bits
Graphics card: Apple M1 Apple 4.1 Metal - 76.3
Broken: version: 3.2.1, branch: master, commit date: 2022-07-05 15:44, hash:
a2d59b2dac
Worked: 3.1
Affected by
80859a6cb2
Diffuse light pass does not work on shaders using 'shader to rgb' node and just comes back blank. it will severely limit the use of compositor with simple NPR style shaders if so. Unless there is a new approach to this node setup I'm not aware of. Other NPR shaders with a colour component also get lost when going between passes.
Attached blend file has simple toon shader. When going from 'combined' pass to the 'diffuse light' pass all information is lost. Not able to isolate the passes that makes up the 'combined' pass for compositing etc.
3.2shadertest.blend
Added subscriber: @Smart_Kyle
Thanks for the report. I'm able to replicate this. Will search the affecting commit.
Added subscriber: @fclem
Broken since:
80859a6cb2
@fclem ^
Added subscriber: @Jeroen-Bakker
The old behavior was incorrect. It is now considered as emission as it should have been.
However, it doesn't even work as the emission pass is completely black. That is the real bug to me. I guess that for the emission pass the diffuse shaders are not evaluated (which make sense). Unfortunately, I don't see that being fixed for EEVEE. Maybe @Jeroen-Bakker has an opinion on this.
Note that it is already working as intended in EEVEE-Next.
Ah I see, that's maybe unfortunate, as being able to separate out diffuse colour, diffuse light and specular etc for the compositor on more stylised shaders opened up a lot more options for NPR workflows and it doesn't seem like there's a good alternative with everything being pumped through 1 pass (emission), especially for any screen space effects. For instance something as simple as drawing a 5px line around shadows on an NPR shader is possible with 3.1 EEVEE and a simple compositor node graph on the diffuse light pass.
Hopefully the shadow pass itself on EEVEE next will make up for this, as I'm assuming it will probably be cleaner, but still does not seem as flexible as having specific passes + more parity between NPR and realistic shaders.
Thank you for the reply :)
