2D Animation tab flashes out of control #100332
Closed
opened 2022-08-10 21:30:36 +02:00 by Jeremy · 10 comments
Operating system: MacOS Monterey
Graphics card: Apple M1 Max
Broken: 2.9.3-3.2.2
Worked: Before 2.9.3
Entire editor flashes when trying to draw with Grease Pencil in the 2D Animation view.
Step 1. Load up Blender 3.2.2 with MacOS using Apple M1 Max
Step 2. Select any tool from the 2D Animation layout and move the mouse cursor around. The entire editor flashes and becomes unusable.
**System Information** Operating system: MacOS Monterey Graphics card: Apple M1 Max **Blender Version** Broken: 2.9.3-3.2.2 Worked: Before 2.9.3 **Short description of error** Entire editor flashes when trying to draw with Grease Pencil in the 2D Animation view. **Exact steps for others to reproduce the error** Based on the default startup or an attached .blend file (as simple as possible). **Step 1.** Load up Blender 3.2.2 with MacOS using Apple M1 Max **Step 2.** Select any tool from the 2D Animation layout and move the mouse cursor around. The entire editor flashes and becomes unusable.
Author
Added subscriber: @Jeremation
Added subscriber: @mano-wii
I cannot reproduce this with either the latest stable or current development versions of Blender .
Can you could provide the system-info.txt generated in {nav Help > Save System Info}?
(Note, it's preferable to use Help -> Report a Bug in Blender so there is complete information about the Blender version and graphics cards).
Operating system: macOS-12.2-arm64-arm-64bit 64 Bits
Graphics card: Apple M1 Apple 4.1 Metal - 76.3
I cannot reproduce this with either the latest stable or [current development versions of Blender ](https://builder.blender.org/download/). Can you could provide the `system-info.txt` generated in {nav Help > Save System Info}? (Note, it's preferable to use `Help -> Report a Bug` in Blender so there is complete information about the Blender version and graphics cards). --- **System Information** Operating system: `macOS-12.2-arm64-arm-64bit 64 Bits` Graphics card: `Apple M1 Apple 4.1 Metal - 76.3`
Author
Yep sure thing. Attached the system info below. I can also take a screen recording of it if it's helpful. Should I re-submit with Help -> Report a Bug?
system-info.txt
Yep sure thing. Attached the system info below. I can also take a screen recording of it if it's helpful. Should I re-submit with Help -> Report a Bug? [system-info.txt](https://archive.blender.org/developer/F13364681/system-info.txt)
The hardware actually seems to be the same as the one I used to test, the difference is in the OS version used (12.1 vs 12.2)
Version 12.1 has been around for quite a while, try upgrade the macOS to the latest version.
The hardware actually seems to be the same as the one I used to test, the difference is in the OS version used (12.1 vs 12.2) Version 12.1 has been around for quite a while, try upgrade the macOS to the latest version.
Author
Hey, I just upgraded to the latest macOS and am still getting the issue. It seems to happen as I move the mouse cursor on any layout. Recorded a video of it glitching.
https://www.loom.com/share/66f4cb58e80c4bbe8df3063f01695961 and sharing the System info again.
system-info.txt
Hey, I just upgraded to the latest macOS and am still getting the issue. It seems to happen as I move the mouse cursor on any layout. Recorded a video of it glitching. https://www.loom.com/share/66f4cb58e80c4bbe8df3063f01695961 and sharing the System info again. [system-info.txt](https://archive.blender.org/developer/F13366287/system-info.txt)
Thanks for the video.
The problem description is misleading. It said "The entire editor flashes and becomes unusable", but only the timeline editor flashes, and it doesn't actually become unusable.
This is a known issue and has been reported before.
So I will merge the reports
Thanks for the video. The problem description is misleading. It said "The entire editor flashes and becomes unusable", but only the timeline editor flashes, and it doesn't actually become unusable. This is a known issue and has been reported before. So I will merge the reports
Closed as duplicate of #92586
Author
Ah apologies, didn't know how to describe it. Thanks for merging it!
2 Participants
Reference: blender/blender#100332
