bpy.ops.file.unpack_all only unpacks one file for similar filenames #100361
Reference: blender/blender#100361
Operating system: Windows 7
Graphics card: NVIDIA GeForce GTX Titan 2015
Broken: 3.3.0 Beta, branch: master, commit hash:
bae2ce0695
Worked: never worked, tested on 2.93, 3.0, 3.1, 3.2, 3.3.0 beta
When you have a .blend file with packed file resources containing files with similar names (i.e. sample.png, sample.png.001, sample.png.002, sample.png.003, etc) and try to unpack these files with File > External Data > Unpack Resources or running bpy.ops.file.unpack_all() in Text Editor with any method as parameter, all files get unpacked with the same name sample.png. Currently there is no known workaround for this so you will always end up with only one file being unpacked which is the last in the list.
1.) Download the attached file same-name-images.blend
2.) Unpack the packed files using File > External Data > Unpack Resources
3.) Check the Info Panel to see where blender saved the file(s)
Notice that only 1 file was unpacked. There are 2 packed files in the attached .blend file, namely sample.png and sample.png.001. The unpacked file results in a file with name sample.png but it really is the packed image sample.png.001.
Added subscriber: @Harry-Kunz
#100462 was marked as duplicate of this issue
A user reported this problem here https://blender.stackexchange.com/questions/271718/blender-overwites-textures-with-same-name-but-different-suffix-number-when-unpac
Added subscribers: @mont29, @lichtwerk
Which of the options are you using?
{F13369318 size=full}
So we have two packed files with relative paths:
with (relative) filepath//sample.png
sample.png.001
with (relative) filepath//another sample/sample.png
What I am seeing is that
textures
folder/c/Users/knia/Desktop/
as a base path which does not exist on my machineSo there does not seem to be an unpacking option to actually unpack these in a relative (to the current blend file) way, which is quite surprising to me.
Note we also have https://docs.blender.org/manual/en/3.4/files/blend/packed_data.html#selective-unpacking.
And even though this is the same underlying code, the documentation and UI actually sound wrong to me
There I have
{F13369423 size=full}
Clicking on the “gift box” icon gives me (only indication is that this will be relative -- only thing to assume is this being relative to the current blend file)
{F13369431 size=full}
But it will try to use the original blends basepath (not existent on my machine)
{F13369443 size=full}
Note to myself: check
WRITE_ORIGINAL
/PF_WRITE_ORIGINAL
.Code might work as expected, will confirm for now though because (at least the selective-unpacking case is very misleading). @mont29 might know more.
I tried all options with .blend file in the Downloads folder because I was trying to find a workaround. These are the Info Panel outputs for each option: (there is some minor inconsistency with a debug trace of bpy.ops.node.select for only the first 2 options but nevermind that).
#Use files in current directory (create when necessary)
bpy.ops.node.select(wait_to_deselect_others=False, mouse_x=309, mouse_y=214, deselect_all=True)
bpy.ops.file.unpack_all(method='USE_LOCAL')
Saved packed file to: C:\Users\xxxx\Downloads\textures\sample.png
#Write files to current directory (overwrite existing files)
bpy.ops.node.select(wait_to_deselect_others=False, mouse_x=390, mouse_y=245, deselect_all=True)
bpy.ops.file.unpack_all(method='WRITE_LOCAL')
#Use files in original location (create when necessary)
bpy.ops.file.unpack_all(method='USE_ORIGINAL')
Saved packed file to: C:\Users\knia\Desktop\sample.png
Saved packed file to: C:\Users\knia\Desktop\another sample\sample.png
#Write files to original location (overwrite existing files)
bpy.ops.file.unpack_all(method='WRITE_ORIGINAL')
#disable auto-pack, keep all packed filesbpy.ops.file.unpack_all(method='KEEP')#Remove Pack
bpy.ops.file.unpack_all(method='REMOVE')
In this sample file there is another folder that serves as a quasi namespace but in the original thread with this issue all files are in the same directory. In the documentation link you have provided it mentions "A single file can be unpacked by clicking on the little “gift box” icon to the left of its file-path UI widget" but I cannot find this "gift box". Where is that? It says left of its file-path UI widge but I don't know where that is.
e.g. Image Editor > N panel >
I do realize though that the two methods are all we have (
LOCAL
will just use the textures folder [stripping any possible subfolder from a relative path leading to name conflicts as mentioned above] andORIGINAL
which is then tied to the folder the image was packed from.In the end this might be a feature request, but we could at least make this more obvious in the UI and/or documentation.
Regarding the name collisions: I think this can only be improved by implementing another unpacking method which respects relative paths and creates them inside the local
textures
folder and/or by mentioning this in the documentation.(the current method can be useful the possible new method - always respecting relative subfolders - could be problematic in certain cases, too)
Regarding the confusion about where "original" locations are really unpacked to, we could do something like P3140 I guess.
Sorry if I was not clear. Please note that name collisions also happen without any subfolders. The issue is that the suffix is removed when unpacking. For example in a list of images all in the same folder:
image.png.001
image.png.002
image.png.003
They all overwirte each other after unpacking and become image.png without the number suffix. Although it is unknown why the suffix was even there after the extension in the first place. Maybe an algorithm has to be implemented that moves .png to the end or just adds another .png extension
Are these named
image.png.001
,image.png.002
etc. on disk? Or is this the image datablock name in blender?Got an example file for this scenario as well?
What is "after the extension"?
Unfortunately I don't know the specifics. I just know that the user who encountered this problem downloaded a blend file (which he couldn't attach because it was too large) with images packed in it that had these images named with a number suffix after the .png extension: image.png.XXX. so he asked how he can unpack them with a uniqie name because the result was only 1 image named image.png. The thread he asked is here https://blender.stackexchange.com/questions/271718/blender-overwites-textures-with-same-name-but-different-suffix-number-when-unpac
Here is a similar problem related to blender's image naming algo that might help. https://blender.stackexchange.com/questions/272346/import-obj-model-pictures-with-the-same-name-will-only-be-imported-once . Maybe the same code change related to naming the images can resolve that issue as well. Notice the way the images have been similarly named after importing into blender with the number suffix.
Added subscriber: @1029910278
I wanted to add that I'm experiencing this too and it's pretty dangerous for packing and unpacking when sending files else where.
It doesn't matter if the files are in the same folder or are each in a separate sub-folder.
As you can see from the image I provided, the files can have only one suffix and still suffer from this issue. If the files are too similarly named then Blender will delete all similar files upon unpacking, even with the Blender add .000 suffix.
I have found no work around as even renaming all image files with a unique name before packing will still have Blender deleting similar image files. What I've noticed that even with renaming (using the Blender Files Display Mode tool) the one set of files saved after unpacking still has the original name.
Here is a image showing a group of offending files that will cause the issue:
