artefacts in transparent area in depth pass #100537
10 Participants
Reference: blender/blender#100537
Operating system: macOS-12.3.1-x86_64-i386-64bit 64 Bits
Graphics card: AMD Radeon Pro Vega 64 OpenGL Engine ATI Technologies Inc. 4.1 ATI-4.8.15
Broken: version: 3.2.1, branch: master, commit date: 2022-07-05 15:44, hash:
a2d59b2dac
If objects have parts that are transparent, it will create artefacts in the depth pass
Check out the attached files. You can clearly see the issue if you check the compositing tab and reduce the exposure.
depth_issue.blend.zip
Added subscriber: @Funnybob
Thanks for the report. I'm not able to repro it
Added subscriber: @pixeltrain3d
Hi Robert, had problems with your scene because of missing stuff.
I think, @PratikPB2123 had also the missing texture on the objects, so he doesn't see the problem. It's only geometry, so no problem.
But built a comparable scene with leafs (transparencies).
I also get artifacts in the depth pass, looking like pixels which have extrem values in the areas of the leafs with the alpha textures.
Both on CPU and GPU in Blender 3.2.2
Transparent Bounces are 200, no denoiser
I'm on Mac 12.5.1
Oh! That's strange. I did pack the file before sending it. Here's the leaf texture.
Added subscriber: @mano-wii
There must have been a problem choosing the file.
There's no material assigned to the leafs, so I'm not sure what to do with the imagem attached.
Note that this problem appears to be the same as described in #97562 (Noisy in Mist Pass) (closed as a duplicate of #66149, but perhaps better separated).
@mano-wii Just take the leaf texture and apply it to the leaf shader of the original file. :-)
Hi, not sure where to apply texture. Node group you've been using in the file is linked data block.
Please either attach
IS_Licuala_Grandis_wind.blend
or make a local scenario where we can redo the problem.depth_issue.blend.zip
Try this one instead, Thanks
Looks like it affect the mist, depth and position passes too. So it's more serious that I thought. Because of this issue, it makes all 3 AOVs useless. It's a major issue.
Added subscriber: @jbverdier
I can confirm the bug, it's really annoying when building natural environments (most of the vegetation assets will use alphas for the leaves) and rendering the mist or position pass.
To compare, Clarisse makes the clip map available in raytracing, maybe that would help as the noise doesn't seem to appear in eevee.
Added subscriber: @AnishSreedhar
For now only workaround is to filter out semi transparent alpha using math node and just use pure black and white alpha
Added subscriber: @zrp
This is really a frustrating bug, getting this to work is crucial for many of the renders. I hope this will be fixed soon.
Added subscriber: @Sergey
Thanks for the report, but it is not really a bug.
The Depth pass is only written for the first sample, so that there is no depth interpolation is going on. This leads to the visual artefacts in mixed transparency cases like the one form the example file in this report.
If you are fine with interpolated depth then using Denoising Depth (available when enabling Denoising Data pass) will give you the result you expect.
Attention, this bug report is not about missing AA in the depth pass. This is good so, because data passes should never be anti-aliased.
But in my tests I see that you will find pixel in the depth pass which make no sense in the depth value in relation to the surrounding areas. So the should be sampled more accurate.
(Sorry, no programmer but comper)
To me it seems that the depth pass behaves according to the setup.
Those artefacts happens on a semi-transparent are from which ray bounces and does not hit anything else, but the depth is not recorded because of the value of the Alpha Threshold.
Thanks for the repley. As you said, only Sample 1 is used. So it will not help to increase the samples, right?
What would be a production solution for that? Any ideas or improvements in mind?
Would be so useful ...
Increasing the number of samples indeed will not help.
You can try two things:
ok, thx
Humm, if I may.... It is a bug. I've worked with Renderman, Arnold, Mental Ray, Guerilla and even Maya's renderer and none of them has this issue. It's not a problem with half transparent objects. The edges on the leaves all 100% transparent and therefor should be ignored. It should not be fixed by denoising because this will create antialiasing and zDepth should not be antialiased. So I would like you to reconsider and reopen that task. It's a major issue for anyone who has to deal with vegetation. Thanks.
The far edges are 100% transparent, but there is this anti-aliased region around the leaves edge where the alpha values are neither fully transparent nor fully opaque. You can clearly see this in the image editor by choosing the Alpha as the display channel:
So what is happening in the pixels which appear to be artefacts is the following:
But even if the ray did transmit instead of reflect then the depth pass on that pixel would have been much different from the surrounding values.
Having new information form you that you don't want anti-aliased depth, but fine with the binary separation of alpha channel then the options are:
I have worked with mentalray, v-ray, arnold, redshift, mantra. None of the rendering engines have this issue. Its definitely a bug, Please consider reopening this task.
This issue was referenced by
3d41d0b1b5
Changed status from 'Archived' to: 'Resolved'
Added subscriber: @brecht
Looked at this together with @Sergey, I committed a change that fixes the gaps at least. However the resulting depth pass is still noisy, just like it is for motion blur and depth of field.
Fixing the noisy may require making Cycles work a bit more like a rasterizer, which is tricky as we are doing pure path tracing and this would be a big change. One possible solution would be supporting an option to use the minimum depth over all samples, which is not quite the same but maybe better. However improving that I consider outside the scope of the bug tracker.
719ad4f93f
ca5062071c
