OBJ exporter does not properly export "image sequence" texture names #100669
Blender Cloud
Documentation
Eevee & Viewport
Import and Export
Rendering & Cycles
Add-ons (BF-Blender)
Add-ons (Community)
Reference: blender/blender-addons#100669
In the output directory, each of the 10 .mtl files have the same image name (i.e the first image in the sequence). Expected result is that each exported frame would have the correct filename of an "image sequence" texture type.
This is the 4th .mtl file in the sequnce, but as you can see refers to Image0001.png
Added subscriber: @GavinfSmith
Added subscriber: @aras_p
@GavinfSmith can you also attach a .blend file that reproduces the issue?
bakebug.zip
See attached. Each image name in the .mtl files refers to the same map name instead of sequential file names.
Thanks for the quick response!
Cheers
Gavin
When exporting an OBJ sequence, the material files have incorrect image texture names if an image sequence sequence has been used.to OBJ exporter does not properly export "image sequence" texture namesChanged status from 'Needs Triage' to: 'Confirmed'
This issue was referenced by blender/blender@6133434478
This issue was referenced by blender/blender@67dcdebb3a
