SSS effect disappears when Mix Shader Node includes Shader To RGB Node #100904
5 Participants
Reference: blender/blender#100904
Operating system: Linux-5.15.0-47-generic-x86_64-with-glibc2.35 64 Bits
Graphics card: NVIDIA GeForce RTX 3070 Ti/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 515.65.01
Broken: version: 3.3.0, branch: master, commit date: 2022-09-06 15:39, hash:
0759f671ce
Worked: 2.93.9
SSS effect disappears when Mix Shader Node includes Shader To RGB Node.
See the attached blend file and video.
sss_bug_report.blend
sss_bug_report.mp4
When the Factor of the Mix Shader Node is 0, the output of the Mix Shader Node is expected to be the same as the Principled BSDF Node.
According to the documentation this might be by design, but it worked fine in 2.93.
Added subscriber: @nagadomi-4
Added subscriber: @mano-wii
Changed status from 'Needs Triage' to: 'Needs Developer To Reproduce'
Looks like a variation of the same bug described in #100125
In the description of the commit
80859a6cb2
states that:However, the manual states that:
So I'm still not sure if any downstream BSDF can work with ShaderToRGB + Screen Space Reflection.
Personally, I believe that in the special case of MixShader with Factor at 0 or 1, it should perform as SwitchNode.
This is because ShaderEditor does not have SwitchNode and Mix * Node has been used instead.
I am not sure if this is possible with the current implementation of Blender.
Also this is not a strong request, I just wanted to make sure this is the intended behavior.
Added subscriber: @PaindavoineRomain
Is there a workaround ? For instance I need to switch from a NPR shader to a realistic shader with a mix node, should I stop the render, unplug the node, then render again ?
I think there should be a bypass when the mix shader is set to 0 or 1.
Also, there is no way to use the result of the SSR to use on a shader with Shader to RGB ?
This issue was referenced by
6d7a067a83
Changed status from 'Needs Developer To Reproduce' to: 'Resolved'
