File Browser's File Drop features often fails when dragging items to the main region of the browser (macOS) #101033
Reference: blender/blender#101033
Mac Pro 2010 (x86)
macOS 10.14.6 Mojave:
Graphics card: Radeon RX 560 4GB
Broken: 3.3 LTS.
Worked: all previous ones.
File Browser's File Drop feature fails (more often than not) if a file or directory is dropped onto its main region. It works consistently well if dropped onto any other region of the browser.
If I drag and drop some folder or file from the Finder onto any other region. It works every time.
Added subscriber: @UseTheFarce
Added subscriber: @OmarEmaraDev
We are getting similar reports on MacOS, so it might be related. #100899
Can you try dragging and dropping an image into the node shading editor and see if you can replicate the issue in the aforementioned report?
Dragging and dropping images to the Shader Editor works perfectly in my case, no matter the image type.
(This is on an old x86 Mac Pro tower. I'll update the system information of my opening post to reflect that)
Added subscriber: @iss
This looks like it's the same issue as #100899. Please check if Blender's file browser window position makes difference on where dead areas are - if I resize window to half of a screen, dropping does not work if window is on right side, but works if window is on left side of screen.
I can confirm that behavior. Using the freeware utility Rectangle to precisely position the file browser in each half of the screen and other positions and sizes, I see the following:
Full height, half width window, set at the left half of screen: always works.
Full height, half width window, set at the right half of screen: doesn't work.
Full height, half width window, set at the middle third of screen: doesn't work.
Half height, full width window, set at the top half of screen: doesn't work.
Half height, full width window, set at the bottom half of screen: always works.
This one is curious:
Half height, full width window, set at the middle third of the screen's height (leaving empty space above and below): if I drop items onto it, the dead area happens to be below the screen's middle height (instead of above it, as could maybe be expected from it fully working when it is at the bottom half).
I hope this helps.
Thanks for checking. Since this seems to be same issue, so will merge reports.
Closed as duplicate of #100899
