bool nodes 's edge out have rubish edge #101067
6 Participants
Reference: blender/blender#101067
Graphics card: Quadro RTX 4000/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 516.40
Broken: version: 3.3.0, branch: master, commit date: 2022-09-06 15:39, hash:
0759f671ce
bool edge bug.blend
Added subscriber: @SensArice
Added subscribers: @HooglyBoogly, @iss
Can confirm the issue. I am not quite up to date on current boolean status. Also can't quite map node functionality to modifier to compare these directly if that is even possible.
@HooglyBoogly is node supposed to produce as clean mesh as possible, or is result like this expected?
I don't know about the internals of the boolean implementation, but I think we should expect that this doesn't happen, I'd call this a bug.
Added subscribers: @howardt, @lichtwerk
The boolean modifier requires two meshes, whereas the node seems to happily act on a single mesh (this then has the "extra" edges).
If the three cubes are separated into individual objects and then booled, it works as expected:
bool edge three meshes.blend
@howardt : was this by design (ability to act on a single mesh)? Or should we just pass on the original mesh in case only a single input is provided?
The Boolean modifier has, by design, the idea that you can have the other operand be a collection, and that collection can be empty. The effect of doing this is that the modifier will detect and resolve self-intersections, which is a useful feature that people wanted. So in the modifier, this is by design and not a bug.
I had less to do with the design of the Boolean Geometry Node. It doesn't offer the distinction between the other operand being a single object and it being a collection, as far as I can tell. But I would still think it is useful to use the Boolean Geometry Node to resolve self intersections on a single object.
Now, one could argue that leaving the "Self Intersect" box unchecked should cause the code not to do the self-intersects check -- in other words, just return the same input that it was given. I have been regarding the "Self Intersect" flag as an optimization, not a guarantee that self-intersections will not be found: if it is checked, then the code needed check overlaps between the two arguments (when there are two). When there is only one argument, the "Self Intersect" flag is not currently consulted. If we want to make "Self intersect" a guarantee that self-intersects will be ignored, then that could be done but kind of violates the idea that Boolean is going for: trying to take n meshes, each representing a volume, and coming up with a mesh that encloses the volume represented by the boolean combination of those argument volumes.
I have to ask: If one doesn't want the result-self-intersection behavior then why use the Boolean node in the first place with no other argument? It would be trivial to check the case of "self intersect not checked" and "one argument" and return immediately. Is that what people think should be done? My inclination is to close this issue as "working as intended" but willing to listen to other arguments.
I think the current behavior with self intersections is fine. Maybe it would be more intuitive if it didn't do anything here unless self intersections were turned on, but I could see how that could be inconsistent with the goal when there are multiple.
The issue in the report is the "extra" edges when there's only a single input. Maybe that's inherent with the way self intersections are calculated, or maybe it could be resolved, I'm not sure.
The "extra" edges are completely expected if the boolean operation is doing self intersection: those edges are the result of that self-intersection.
@howardt Maybe I don't understand it correctly, but
Self Intersection
is turned off in the node, so why does your explanation make sense?@JacquesLucke It only makes sense if one understands the "Self Intersection" flag to be an optimization, not a contract. Which is the way I thought of it. But I understand that that may not be intuitive.
Does this really matter to people? As I said above, I can trivially change the code so that it does nothing when there is only one mesh and "Self Intersection" is not checked, but then why would one even use such a node?
I think the node should consider other possibilities, such as this, there are always some missing lines.
