GPencil: framechanging does not evaluate keyframed layer transform correctly (if this would result in identity matrix) #101164
5 Participants
Reference: blender/blender#101164
Operating system: MacOs 12.6
Graphics card: M1
Broken: 3.4.0 (3.4.0 2022-09-17)
Worked: ?
When animating Grease Pencil Transforms in Stroke Properties, there is a refresh problem (it doesn't refresh) when going back to first frame of animation using Jump to first frame ...
Workaround seems to be clicking a keyframe in the Dopesheet.
Jump to Previous keyframe
button from timeline header(notice viewport doesn't update. Clicking anywhere in dopsheet later updates the viewport)
Kapture 2022-09-18 at 12.59.55.mp4
AnimatedGP_Transform_Refresh_Bug.blend
Seems to only be the case with exactly 0° rotation?
If I change the first rotation keyframe to have a value of 1°, this all of a sudden seems to work fine:
AnimatedGP_Transform_Refresh_Bug_repro.blend
going to / going from zero rotation goes wrong:
gpencil_layer_transform_zero_rotation_.blend
Added subscriber: @Pyer
#101325 was marked as duplicate of this issue
Added subscriber: @antoniov
Added subscriber: @amelief
I am not sure I understand the issue.
If the issue is that we cannot see the keyframes in the dopesheet, that is because the dopesheet is in 'Grease Pencil' mode, and thus only displaying layer keyframes (meaning drawn keyframes, and not transform or gpencil data keyframes). If you switch to the standard mode of the dopesheet, you can see that the keyframes are correctly created.
Hello! The issue is that when animating a Grease Pencil Transform, when you press the Icon to go to the first frame of the animation (or jump to previous/next key) the viewport does not refresh the animated GP transform (timecode 00:17 in the video).
It refreshes the viewport when you click anywhere in the Dopesheet window (GP or normal).
Animated GreasePencil transform refresh bugto GPencil: Jump to previous keyframe doesn't update the viewport for transform propertiesAdded subscriber: @lichtwerk
Jumping to next seems to go fine on my side.
Could it be that this is only the case with exactly 0° rotation?
@lichtwerk
Haha you're right!! So weird!!!
So this is true for all framechanging (mouse, frame offset, frame jump, ..)
Seems like greasepencil is just not evaluating right for zero rotation keyframes
GPencil: Jump to previous keyframe doesn't update the viewport for transform propertiesto GPencil: framechanging does not evaluate keyframed layer transform rotation of exactly zero degrees correctly@lichtwerk
Oh wait it actually does the same thing with Location, you have to put a different value than zero for it to refresh correctly...
Scaling seems to be ok.
Ah, there are (optimization checks for this in
BKE_gpencil_prepare_eval_data
&BKE_gpencil_update_layer_transforms
Will check on a fix
GPencil: framechanging does not evaluate keyframed layer transform rotation of exactly zero degrees correctlyto GPencil: framechanging does not evaluate keyframed layer transform correctly (if this would result in identity matrix)This issue was referenced by
dfcc8086fb
24814a03b7
1cbfe04638
@lichtwerk Hello and sorry for asking, but is this going to be published to master at some point? I'm still not seeing it in the recent nightly builds. Thanks :)
Probably soonish (just waiting for a second pair of eyes)
Added subscriber: @miya
