Not responding #101258
Closed
opened 2022-09-21 19:19:18 +02:00 by Georgii · 6 comments
Operating system: Windows 11
Graphics card: RTX 3060 TI
Broken: 3.3
(example: 2.79b release)
I am in edit mode and I can't select any vertices nor lines or faces.
I can select vertices only using the letter "a".
go to edit mode and not be able to select anything or deselect anything.
**System Information** Operating system: Windows 11 Graphics card: RTX 3060 TI **Blender Version** Broken: 3.3 (example: 2.79b release) (example: 2.80, edbf15d3c044, blender2.8, 2018-11-28, as found on the splash screen) Worked: (optional) **Short description of error** I am in edit mode and I can't select any vertices nor lines or faces. I can select vertices only using the letter "a". **Exact steps for others to reproduce the error** go to edit mode and not be able to select anything or deselect anything. Based on the default startup or an attached .blend file (as simple as possible).
Author
Added subscriber: @Blenderuser12386982659862
Is this happening in every blend file (also the startup one)? If not, can you add an screenshot or better an example blend file please?
No activity for more than a week. As per the tracker policy we assume the issue is gone and can be closed. Thanks again for the report. If the problem persists please open a new report with the required information.
2 Participants
Reference: blender/blender-addons#101258
