X-Ray using Alpha 1 working different in different blender files versions #101278
Closed
opened 2022-09-22 23:08:57 +02:00 by Antônio Froz · 17 comments
The same object being viewed in edit mode in different versions of blender, with x-Ray active using alpha at value 1, is viewed differently.
I would like to know how to apply the same effect from old files to the new one as I didn't find anything in the settings to change this.
The photos contain two meshes, one high poly that I made the sculpture and the other low poly that is in edit mode.
image.png Old Blender file visualization with x-ray on.
image.png New Blender file visualization with x-ray on.
Both are using the same configuration, but in older file (probably before 2.8), I can see the vertices behind the sculpture and with the fade out effect
The same object being viewed in edit mode in different versions of blender, with x-Ray active using alpha at value 1, is viewed differently. I would like to know how to apply the same effect from old files to the new one as I didn't find anything in the settings to change this. The photos contain two meshes, one high poly that I made the sculpture and the other low poly that is in edit mode. ![image.png](https://archive.blender.org/developer/F13556544/image.png) Old Blender file visualization with x-ray on. ![image.png](https://archive.blender.org/developer/F13556551/image.png) New Blender file visualization with x-ray on. Both are using the same configuration, but in older file (probably before 2.8), I can see the vertices behind the sculpture and with the fade out effect
Author
Changed status from 'Needs Triage' to: 'Needs Developer To Reproduce'
Author
Added subscriber: @Antonio-Manoel-Nogueira-Froz
Member
Changed status from 'Needs Developer To Reproduce' to: 'Needs Triage'
Member
Member
Member
Thanks for the report. Please share your new .blend file.
Author
[New File (X-Ray Not Working).blend](https://archive.blender.org/developer/F13558806/New_File__X-Ray_Not_Working_.blend) New File [Old File (X-Ray Working).blend](https://archive.blender.org/developer/F13558807/Old_File__X-Ray_Working_.blend) Old File
Member
Member
Strange, I tried in another workspace and x-ray mode works.
Its just the file and Layout workspace in which issue is replicable. I'm not sure if this would be consider as a bug.
And thanks for these files.
Strange, I tried in another workspace and x-ray mode works. Its just the file and Layout workspace in which issue is replicable. I'm not sure if this would be consider as a bug. And thanks for these files.
Member
Added subscriber: @EAW
Member
The easiest way I can think of is to click the gear in the upper right of the filebrowser, and un-check Load UI.
The easiest way I can think of is to click the gear in the upper right of the filebrowser, and un-check `Load UI`. ![Load UI.png](https://archive.blender.org/developer/F13579594/Load_UI.png)
Added subscriber: @iss
this could be a bug, because v3d->overlay.backwire_opacity is 0 in this file. It is only set in versioning to 0.5f and there is no way to set this value from UI. Seems to be possible to set via python though. @Antonio-Manoel-Nogueira-Froz do you use any addons? Can you describe how this happened?
this could be a bug, because `v3d->overlay.backwire_opacity` is 0 in this file. It is only set in versioning to `0.5f` and there is no way to set this value from UI. Seems to be possible to set via python though. @Antonio-Manoel-Nogueira-Froz do you use any addons? Can you describe how this happened?
Author
@iss I don't know exactly how it happened, this is a very old file and it works this way, but at that time I was starting in Blender and used many add-ons, there were some retopology ones that changed the interface a lot, like retopoflow. But I can't say when this happen.
But it would be interesting to add this by default in Blender, as it helps a lot when making manual retopology.
@iss I don't know exactly how it happened, this is a very old file and it works this way, but at that time I was starting in Blender and used many add-ons, there were some retopology ones that changed the interface a lot, like retopoflow. But I can't say when this happen. But it would be interesting to add this by default in Blender, as it helps a lot when making manual retopology.
Thanks for information, if this was caused by retopoflow, it seems they have fixed the issue since property is not changed there. In any case this would have to be reported to addon developers, so will close this report.
For user feedback and feature requests I would recommend to check https://wiki.blender.org/wiki/Communication/Contact#User_Feedback_and_Requests. Here we handle only bugs.
> In #101278#1423970, @Antonio-Manoel-Nogueira-Froz wrote: > @iss I don't know exactly how it happened, this is a very old file and it works this way, but at that time I was starting in Blender and used many add-ons, there were some retopology ones that changed the interface a lot, like retopoflow. But I can't say when this happen. Thanks for information, if this was caused by retopoflow, it seems they have fixed the issue since property is not changed there. In any case this would have to be reported to addon developers, so will close this report. > But it would be interesting to add this by default in Blender, as it helps a lot when making manual retopology. For user feedback and feature requests I would recommend to check https://wiki.blender.org/wiki/Communication/Contact#User_Feedback_and_Requests. Here we handle only bugs.
Reference: blender/blender#101278
