Unable to import AutoCAD DXF files and neither able to switch modes with tab key #101308
Blender Cloud
Documentation
Eevee & Viewport
Import and Export
Rendering & Cycles
Add-ons (BF-Blender)
Add-ons (Community)
Reference: blender/blender-addons#101308
Operating system: Windows-10-10.0.19044-SP0 64 Bits
Graphics card: Intel(R) HD Graphics 4000 Intel 4.0.0 - Build 10.18.10.5161
Broken: version: 3.3.0, branch: master, commit date: 2022-09-06 15:39, hash:
blender/blender@0759f671ce
am unable to import AutoCAD DXF files and I am also unable to use the shortcut key Tab to switch from object mode to edit mode. I would appreciate you guiding me and rectifying the query
Added subscriber: @shridesign
Added subscriber: @mano-wii
Apparently you came from #101267 (Python Error ( Not able to add CAD DWG file)) and didn't see the guideline for making a good bug report: https://wiki.blender.org/wiki/Process/Bug_Reports
This bug tracker is only for bugs and errors.
For help using Blender, please try one of the community websites: https://www.blender.org/community/
If you think you found a bug, please carefully follow the instructions. Be sure to provide system information, Blender version, and a .blend file with exact steps to reproduce the problem.
am unable to import AutoCAD DXF files and I am also unable to use the shortcut key Tab to switch from object mode to edit mode. I would appreciate you guiding me and rectifying the queryto Unable to import AutoCAD DXF files and neither able to switch modes with tab keyI am unable to import AutoCAD DXF files and
If you think you found a bug, please submit a new report and carefully follow the instructions. Be sure to provide system information, Blender version, and a .blend file with exact steps to reproduce the problem.
