Multilayer EXR UDIMs display incorrectly #101320
Reference: blender/blender#101320
Broken: since introduction of UDIM in 2.82
This issue was encountered when investigating #100452 (USD Alab v2 import errors)
The attached zip archive contains two blend files, which are identical except that they reference EXR and PNG UDIMs, respectively.
alab_chair_exr_udim.blend
, referencing the EXRs, displays incorrectly in the viewport (first image).alab_chair_png_udim.blend
, referencing PNGs, displays correctly (second image).blender_exr_udim_bug.zip
When the EXRs have multiple layers, even just 1, the problem occurs:
Multilayer EXRs have a custom loading sequence and storage location inside the
Image->rr (RenderResult)
field.That code is quite intertwined with the RenderLayer/RenderPass system. It's unclear why this was chosen for multi-layer images. Maybe because it was the system that knew how to select layers/passes already? In any case, it is not UDIM aware and I'm not sure if the RenderLayer/RenderPass system should be aware of them.
Since I don't have a full understanding of the history here a proper fix seems non trivial at first inspection.
Added subscriber: @makowalski
UDIM EXR textures display incorrectlyto Multilayer EXR UDIMs display incorrectlyAdded subscriber: @deadpin
Will place this up for grabs right now. This needs HQ insight to help fill in the history and decide how to proceed; will try to surface to them in the meantime.
Added subscriber: @NekoSilverfox
Removed subscriber: @NekoSilverfox
Added subscriber: @brecht
I expect it was just the quickest way to get something working at the time.
A proper fix may indeed take some significant refactoring.
I think ideally UDIMs, layers/passes, views and even sequences should all be possible to combine in a single image datablock, and be orthogonal concepts. The image multilayer code outside of rendering should stop relying on
RenderResult
.We already have a
ListBase tiles
andListBase views
inImage
, I think we should also have aListBase layers
ofImageLayer
, which contains aListBase passes
ofImagePass
. These layer and pass lists can be populated from a file on disk, render result, and eventually manually created by the user. Views already work like this, and layers and pass populating and syncing could be done in all the same places.Image buffers are currently stored in an image cache that has key
(frame, view)
, whereframe
is also abused as UDIM tile index. Instead the key should be(frame, view, tile, layer, pass)
.This also aligns with the plans for texture layers and baking, where we want to rely on multilayer images like this more. The idea there is to bake multiple passes to multilayer image datablocks. This datablock could then correspond to a single multilayer EXR file, but also e.g. separate PNG files for each pass. UDIM tiles, views and sequence frames are already separate image files in one image datablock so it's a natural extension to that.
