Error - Import AutoCAD DXF files #101327
Open
opened 2022-09-24 14:16:34 +02:00 by Shripad Phase · 12 comments
Operating system: Windows-10-10.0.19044-SP0 64 Bits
Graphics card: Intel(R) HD Graphics 4000 Intel 4.0.0 - Build 10.18.10.5161
Broken: version: 3.3.0, branch: master, commit date: 2022-09-06 15:39, hash: blender/blender@0759f671ce
Addon Information
Name: Export Autocad DXF Format (.dxf) (2, 2, 3)
Author: Remigiusz Fiedler (AKA migius), Vaclav Klecanda
Iam unable to import AutoCAD DXF files and
I am also unable to use the shortcut key Tab to switch from object mode to edit mode.
I would appreciate you guiding me and rectifying the query
Python: Traceback (most recent call last):
  File "C:\Program Files\Blender Foundation\Blender 3.6\3.6\scripts\addons\10_import_dxf\__init__.py", line 521, in execute
    read(self.report, self.filepath, merge_options, self.import_text, self.import_light, self.export_acis,
  File "C:\Program Files\Blender Foundation\Blender 3.6\3.6\scripts\addons\io_import_dxf\__init__.py", line 101, in read
    errors = do.entities(os.path.basename(filename).replace(".dxf", ''), new_scene)
  File "C:\Program Files\Blender Foundation\Blender 3.6\3.6\scripts\addons\io_import_dxf\dxfimport\do.py", line 1609, in entities
    self.combined_objects((en for en in self.dwg.modelspace() if is_combined_entity(en)), scene)
  File "C:\Program Files\Blender Foundation\Blender 3.6\3.6\scripts\addons\io_import_dxf\dxfimport\do.py", line 1513, in combined_objects
    o = self.call_object_types(TYPE, by_att, group, name, scene, False)
  File "C:\Program Files\Blender Foundation\Blender 3.6\3.6\scripts\addons\io_import_dxf\dxfimport\do.py", line 1362, in call_object_types
    o = type_func(entity, scene, name)
TypeError: 'NoneType' object is not callable
  • import attached .dxf file
Thank You So much for providing such a wonderful software and Your Support
Layout 4 3 D -22 09 22.dxf
Apartment Duplex 02112023.dxf
**System Information** Operating system: Windows-10-10.0.19044-SP0 64 Bits Graphics card: Intel(R) HD Graphics 4000 Intel 4.0.0 - Build 10.18.10.5161 **Blender Version** Broken: version: 3.3.0, branch: master, commit date: 2022-09-06 15:39, hash: `blender/blender@0759f671ce` Worked: (newest version of Blender that worked as expected) **Addon Information** Name: Export Autocad DXF Format (.dxf) (2, 2, 3) Author: Remigiusz Fiedler (AKA migius), Vaclav Klecanda **Short description of error** Iam unable to import AutoCAD DXF files and I am also unable to use the shortcut key Tab to switch from object mode to edit mode. I would appreciate you guiding me and rectifying the query ``` Python: Traceback (most recent call last): File "C:\Program Files\Blender Foundation\Blender 3.6\3.6\scripts\addons\10_import_dxf\__init__.py", line 521, in execute read(self.report, self.filepath, merge_options, self.import_text, self.import_light, self.export_acis, File "C:\Program Files\Blender Foundation\Blender 3.6\3.6\scripts\addons\io_import_dxf\__init__.py", line 101, in read errors = do.entities(os.path.basename(filename).replace(".dxf", ''), new_scene) File "C:\Program Files\Blender Foundation\Blender 3.6\3.6\scripts\addons\io_import_dxf\dxfimport\do.py", line 1609, in entities self.combined_objects((en for en in self.dwg.modelspace() if is_combined_entity(en)), scene) File "C:\Program Files\Blender Foundation\Blender 3.6\3.6\scripts\addons\io_import_dxf\dxfimport\do.py", line 1513, in combined_objects o = self.call_object_types(TYPE, by_att, group, name, scene, False) File "C:\Program Files\Blender Foundation\Blender 3.6\3.6\scripts\addons\io_import_dxf\dxfimport\do.py", line 1362, in call_object_types o = type_func(entity, scene, name) TypeError: 'NoneType' object is not callable ``` ![image.png](https://archive.blender.org/developer/F13563067/image.png) **Exact steps for others to reproduce the error** - import attached .dxf file Thank You So much for providing such a wonderful software and Your Support [Layout 4 3 D -22 09 22.dxf](https://archive.blender.org/developer/F13590705/Layout_4_3_D_-22_09_22.dxf) [Apartment Duplex 02112023.dxf](attachments/6a7c80b3-3489-4dfc-99f8-26e7cb8bfdd4)
Author
Added subscriber: @shridesign
Member
Added subscriber: @OmarEmaraDev
Member
Member
Can you attach a sample DXF file that reproduces this issue?
Author
In Response to Your request, I am attaching the DXF file for further processing...
[Layout 4 3 D -22 09 22.dxf](https://archive.blender.org/developer/F13590705/Layout_4_3_D_-22_09_22.dxf) In Response to Your request, I am attaching the DXF file for further processing...
Member
Member
Can confirm. Looks like the try except is perhaps misplaced.
Author
No, it's not Looks like the try except is perhaps misplaced,
I have tried several times, but I am unable to input the DXF file.
And
No, it's not Looks like the try except is perhaps misplaced, I have tried several times, but I am unable to input the DXF file. And I am also unable to use the shortcut key Tab to switch from object mode to edit mode. I would appreciate you guiding me and rectifying the query
Author
Changed status from 'Confirmed' to: 'Needs Triage'
Shripad Phase self-assigned this 2022-10-07 19:16:02 +02:00
Author
If you could resolve my issue, I would greatly appreciate it.
1.Not unable to input the DXF file
2.Not unable to use the shortcut key Tab to switch from object mode to edit mode.
Thanks
If you could resolve my issue, I would greatly appreciate it. 1.Not unable to input the DXF file 2.Not unable to use the shortcut key Tab to switch from object mode to edit mode. Thanks
Member
Shripad Phase was unassigned by Omar Emara 2022-10-10 09:16:49 +02:00
Member
The report is already confirm, please don't change the status. You will just have to wait for the add-on maintainer to look into it.
2 Participants
Reference: blender/blender-addons#101327
