Cycles: Compositor File Output BW Color Option Issue (again) #101782
Closed
opened 2022-10-12 22:42:58 +02:00 by MC · 9 comments
Because somehow, in the previous issue I opened, my comment didn't post at all when I had updated the google drive link.
Operating system: Windows-10-10.0.19044-SP0 64 Bits
Graphics card: NVIDIA GeForce GTX 960M/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 512.59
Broken: version: 3.3.0, branch: master, commit date: 2022-09-06 15:39, hash: 0759f671ce
Working: Unknown
Discovered an issue where a compositor's File Output node is set to BW, it fails to output any emission.
Download this file: https://drive.google.com/file/d/19vkFo1q_K0a_ppQKzBc3_fsRyJAq5Lq_/view?usp=sharing
Load up the following file and render out a single image. Renders out a pure black image.
The result is the same if you use the Emit pass.
Strangely, it works if you put in an RGB to BW node in between, which makes me think the file output is drawing exclusively from the R channel.
Extra Notes
This has several other issues included with it. If preferred, I can make multiple reports to them and link them back here.
The issues in particular:
When rendering out with this file, there will be a brief switch of view layers in the render output to "All" and "Turret Barrel", despite having Render Single Layer turned on.
This seems fixed in 3.6 onwards:
The outliner on the right and below does not show updated view layers that are supposed to be off, despite the animation data being active. Only when you click on some of them (not on the EYE icon, just their names!) will they update appropriately, instead of constantly reflecting the animation data (Animation workspace -> LayerToggles NLA).
Because somehow, in the previous issue I opened, my comment didn't post at all when I had updated the google drive link. **System Information** Operating system: Windows-10-10.0.19044-SP0 64 Bits Graphics card: NVIDIA GeForce GTX 960M/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 512.59 **Blender Version** Broken: version: 3.3.0, branch: master, commit date: 2022-09-06 15:39, hash: 0759f671ce Working: Unknown **Short description of error** Discovered an issue where a compositor's File Output node is set to BW, it fails to output any emission. **Exact steps for others to reproduce the error** Download this file: https://drive.google.com/file/d/19vkFo1q_K0a_ppQKzBc3_fsRyJAq5Lq_/view?usp=sharing Load up the following file and render out a single image. Renders out a pure black image. The result is the same if you use the Emit pass. Strangely, it works if you put in an RGB to BW node in between, which makes me think the file output is drawing exclusively from the R channel. **Extra Notes** This has several other issues included with it. If preferred, I can make multiple reports to them and link them back here. The issues in particular: When rendering out with this file, there will be a brief switch of view layers in the render output to "All" and "Turret Barrel", despite having Render Single Layer turned on. This seems fixed in 3.6 onwards: `The outliner on the right and below does not show updated view layers that are supposed to be off, despite the animation data being active. Only when you click on some of them (not on the EYE icon, just their names!) will they update appropriately, instead of constantly reflecting the animation data (Animation workspace -> LayerToggles NLA).`
Author
Added subscriber: @MajorCooke
Author
This time the materials are included to replicate the problem.
da.buy commented 2022-10-13 01:03:14 +02:00 (Migrated from localhost:3001)
Added subscriber: @da.buy
Can confirm, the compositor file output node will only use the red channel for bw render if forced to implicitly convert rgb input.
Here an easier test setup:
comp_file_output_implicit_bw_conversion_bug.blend
Can confirm, the compositor file output node will only use the red channel for bw render if forced to implicitly convert rgb input. Here an easier test setup: [comp_file_output_implicit_bw_conversion_bug.blend](https://archive.blender.org/developer/F13669846/comp_file_output_implicit_bw_conversion_bug.blend)
Author
There's a few other additional bugs I noticed which I've included under the "Extra Notes" that may be worth looking into.
Philipp Oeser removed the
label 2023-02-10 09:31:29 +01:00
Sergey Sharybin added
and removed
labels 2023-02-15 12:43:38 +01:00
Member
>The outliner on the right and below does not show updated view layers that are supposed to be off, despite the animation data being active. Only when you click on some of them (not on the EYE icon, just their names!) will they update appropriately, instead of constantly reflecting the animation data (Animation workspace -> LayerToggles NLA). This seems fixed in 3.6 onwards
Member
This was also fixed in 3.6 (presumably by 1771ded381)
@MajorCooke : can you confirm?
If so, I think this report should be closed (if there are remaining issues, it might be better to report these separately).
> Can confirm, the compositor file output node will only use the red channel for bw render if forced to implicitly convert rgb input. > Here an easier test setup: > > [comp_file_output_implicit_bw_conversion_bug.blend](https://archive.blender.org/developer/F13669846/comp_file_output_implicit_bw_conversion_bug.blend) This was also fixed in 3.6 (presumably by 1771ded381125409a578ca57093f79219fe5cf79) @MajorCooke : can you confirm? If so, I think this report should be closed (if there are remaining issues, it might be better to report these separately).
Philipp Oeser added
and removed
labels 2023-07-19 11:42:50 +02:00
Member
No activity for more than a week. As per the tracker policy we assume the issue is gone and can be closed. Thanks again for the report. If the problem persists please open a new report with the required information.
Blender Bot added
and removed
labels 2023-08-15 11:32:16 +02:00
Reference: blender/blender#101782
