Vector Math's "Refract" node gives wrong results. #102068
5 Participants
Reference: blender/blender#102068
Broken: version: 3.3.0, branch: master, commit date: 2022-09-06 15:39, hash:
0759f671ce
Worked: Never! Not since the node was introduced.
The "Refract" node, contained in "Vector Math", gives wrong results. An easy one to spot happens when the incident vector is not normalized, but it's not the only one.
I've checked the source code in
intern/cycles/util/math_float3.h
and confirmed the formula is slightly wrong.Spotted by Ian Ambrose on devtalk
Use the Refract node and input a non-normalized incident vector.
Added subscriber: @Gabriel-Solis
Added subscriber: @edward88
Hm, i can not spot the difference. Everything inside the root function is identical with
k
.So according to the formula, the calculation in the return statement should be
sqrt(k) * normal + eta * (incident - dot(normal, incident) * normal)
expand with
eta
eta * incident - eta * dot(normal, incident) * normal + sqrt(k) * normal
collapse
normal
eta * incident - (eta * dot(normal, incident) + sqrt(k)) * normal
Am i missing something?
Are you referring to the changes in D16341? If so, the fix is that the incident vector is now normalized before the calculation. If not, reading the patch message may clarify things a bit.
Yes i did not see the patch when i wrote that, ty
Added subscriber: @CharlieJolly
Hi, part of the issue is that it is based on the glsl and osl version of the function.
https://registry.khronos.org/OpenGL-Refpages/gl4/html/refract.xhtml
This is one of those bug/not bug things.
To quote the glsl docs…
The input parameters I and N should be normalized in order to achieve the desired result.
In either case the patch would need to touch the Eevee and Cycles code paths too. The other solution is to make sure the documentation and tooltips advise the inputs should be normalised.
Added subscriber: @brecht
For the vector math node it would be reasonable to make it work with unnormalized vectors, since it's more high level functionality. I would not consider that a bugfix but a useful improvement to the node.
The general math library implementation that can be used by other parts of the code should not be changed, to avoid a performance impact. A second function can be added that works with unnormalized vectors, to be used by the vector math node.
Added subscriber: @OmarEmaraDev
Since it was established that this is not exactly a bug and a patch was already submitted, I will archive this for now.
