Crash Python API - GPUOffScreen.draw_view3d() crashes blender with draw_type = POST_VIEW but works with draw_type = POST_PIXEL #102526
Reference: blender/blender#102526
Operating system: Windows-10-10.0.22000-SP0 64 Bits
Graphics card: GeForce RTX 3070/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 457.51
Broken: version: 3.3.1, branch: master, commit date: 2022-10-04 18:35, hash:
b292cfe5a9
When using [GPUOffScreen.draw_view3d() ]] in a draw_handler , blender crashes when running the [ https://docs.blender.org/api/current/gpu.shader.html?highlight=gpu+shader+from_builtin#built-in-shaders | 3D_IMAGE builtin shader if the draw_type was set to POST_VIEW but works if the draw_type was set to POST_PIXEL.
Open CrashScriptDrawView3D.blend
Run the script Crash3D and blender will crash
Run the script NoCrash2D, and it will draw the camera view in the viewport without crashing
blender.crash.txt
Added subscriber: @BetaDab
Added subscriber: @regcs
I thought this could be related to #84402, so I tried to use the hack proposed by @regcs in that task.
I added the script NoCrash3D to the file CrashScriptDrawView3D.blend. In this script, I separated the offscreen drawing from the drawing of the offscreen in a
prepare()
function and adraw()
function.This approach doesn't crash blender, but makes the viewport unresponsive and just draws a black square instead of the camera view.
Operating system: Kubuntu 22.04 Linux-5.15.0-53-generic-x86_64-with-glibc2.35 64 Bits
Graphics card: NVIDIA GeForce RTX 3070/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 510.85.02
b292cfe5a9
The script Crash3D also crashes on the same machine with Kubuntu 22.04.
On Kubuntu, the script NoCrash3D behaves differently than windows. Blender doesn't crash, the viewport remains responsive, but draws some psychedelic stuff (lol).
Here are two videos of the viewport after I run the script NoCrash3D on Kubuntu 22.04:
https://youtu.be/wAfb53Cqgq4
https://youtu.be/yzfFezErT4M
In the second video, it seems that there are pieces of the splashscreen being rendered on the square.
Weirdly enough, if I don't run the
prepare()
function before adding it as adraw_handler
, the workaround proposed by @regcs in #84402 works!So now I have a workaround that enables me to show the expected behavior. You can test it by running the script WorkingNoCrash3D in the attached file.
Here is a video of the script running on Kubuntu 22.04:
https://youtu.be/3WMzrdZY0b0
Edit:
Also tested the workaround on windows, and it works.
Added subscriber: @mano-wii
Thanks for the report, I can confirm the problem.
It happens because
DRW_draw_render_loop_ex
is called insideDRW_draw_render_loop_ex
andDRWManager
(DST) is recreated causing problems for code continuity.Shader needs to be changed to
shader = gpu.shader.from_builtin('IMAGE')
in newer versions, but it still crashes inPOST_VIEW
Will dare setting this to high priority since it crashes ans is not an uncommon thing to do in my opinion (and the "2d workaround" is not obvious -- and possibly not what the user is after...)
Of course feel free to lower in priority again if this does not feel important enough to fix...
