Grease Pencil: Erasing/Cutting does not auto-key layers #102623
8 Participants
Reference: blender/blender#102623
Operating system: Windows-10-10.0.19045-SP0 64 Bits
Graphics card: NVIDIA GeForce GTX 1060/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 516.59
Broken: version: 3.5.0 Alpha, branch: master, commit date: 2022-11-17 22:27, hash:
2c096f17a6
Usually whatever edits are done in Edit, Sculpt or Draw mode result in creating a new keyframe, if auto keying is enabled in the timeline.
The issue is that the Eraser brush and the Cutter tool in Draw Mode do not result in auto-keying.
This is easily resulting in lost work.
Note: This is the same issue with the Annotate tools
On the other hand if "Use Additive Drawing" (Snowflake icon) is enabled in the header, erasing will result in correct auto-keying behaviour.
This inconsistency doesn't seem intentional.
Added subscriber: @JulienKaspar
Added subscriber: @antoniov
@JulienKaspar hi, thanks for the report. Actually this has been reported before and got closed as a design topic: #74608
There is a workaround to generate a keyframe when erasing-
enable "additive drawing"
. see: D7804: GPencil: Create new frame when Erase only if additive drawing is enabledFor cutter tool, it's' still not creating keyframe.
cc @antoniov
The cutter is designed to use existing frames, but never creates a new one. In the future we could consider this feature, but now it's a limitation.
I see. But I don't understand the reasoning behind this design decision yet and can't find it explained anywhere.
I can only sort of understand the technical reason to do it this way, because erasing by definition is always editing existing strokes.
Issues
IMO the current behavior is a big problem, since it often leads to scenarios where you "accidentally sweep away your footsteps as you walk forward".
Especially with Annotations where there is no way to manually key with
I
or enable "Additive Drawing".It's important to acknowledge that it's a common case to erase 'certain parts' first and add to your drawings.
There is no way Blender warns you that erasing and deleting is not considered for auto-keying, even though any other edit will create a keyframe.
It's also not communicated in the UI that "Additive Drawing" works otherwise. It's only mentioned in the Manual as an additional sentence, but excluded from the tooltip.
The proper workflow currently seems to be to use the
I
shortcut to add a new keyframe manually, or to first do a 'valid' edit that will cause auto-keying to work.That's not ideal, because it instills a distrust in auto-keying. And it leads to manual extra steps to create a keyframe ... the case that auto-keying was designed to prevent.
My Proposal
If Auto Keying is enabled, always treat erasing and deleting of strokes as if "Additive Drawing" is enabled.
This should be the case for both Annotation and Grease Pencil, in any mode!
This behavior would be more aligned with the purpose of auto-keying and make sure that users can rely on it always creating a new keyframe on any edit.
It's the better compromise in my opinion.
Added subscribers: @mendio, @pepe-school-land
About workflow, I would like to hear @mendio and @pepe-school-land opinion.
In any case, we must not mix GPencil and Annotations... the Annotations are a different tool and is not using the same code for drawing. We split the annotation code some time ago, and our plans for future GP 3.0 is split totally the annotations from GPencil object.
Added subscribers: @Pullup, @frogstomp-4
I also find myself relying on autokey to produce new frames when erasing and this does lead to accidents.
Actually I want also to bring @Pullup to this discussion regarding his GP transforms tool. I'd like to see more strict respect of autokey in all aspects:
Hi, I have to agree with @JulienKaspar, the behavior is mistrusting.
You have to really understand how things work and be constantly aware of what will happens with different actions and contexts, that makes it difficult to predict.
I asked an animator that worked on a lot of GP project, she told that it was particularly misleading in edit mode when deleting stroke (no key is added since it's only auto-keying when modifying or adding stroke).
All other animators I asked agree as well, there is a full consensus on this.
Snowflake (additive draw) is indeed duplicating the keyframe when erasing, but animators don't want to keep previous drawing when they start to draw on a new frame, so they never enable this option.
@frogstomp-4 Thank you for bringing me here. But I think talking about external addons behavior here is out of this discussion scope.
Don't worry though, I agree with you on this point, and this has been on my personal addon's todo list for a while, it's just that respecting autokey is not that easy to implement in Python ^^.
I think the current behavior is legacy from when Grease Pencil didn't use Autokey.
Autokey for Grease Pencil was introduced in Blender 2.93 https:*developer.blender.org/rB6a662ffda836
Whit autokey now fully functional, it make sense to treat any single change on the strokes as a new keyframe.
Whichever tool is used in Draw Mode (Draw, Erase, Tint, cutter) or when deleting points/strokes in Edit Mode.
Yes, I agree with Matias
Added subscriber: @lichtwerk
I have changed the
Eraser
and now if you haveauto-key
enabled, a new frame is created.About
Cutter
the things are totally different. The problem with Cutter is that needs to find what points need to cut and also is multiframe, so it's not possible (it's possible, but changing all the code of the operator) to detect if need to create the frame or not...also, if you are using multiframe would need to create a lot of frames in the new one. If we duplicate the frame before, we could use theCutter
, don't delete anything but create the frame anyway.As we are planning GPencil 3.0, IMHO it doesn't worth the complexity to change all the code that surely we are going to deprecate. I would set this as
