New OBJ exporter does not export groups by material if dense mesh #102672
Reference: blender/blender#102672
Operating system: Windows
Broken: (example: 3.5.0)
Blender obj exporter does not export material groups within the .obj exporter if mesh is hight than aprox. 3500 polys
test_export_material.blend
In the atteched file you can find two spheres with two material groups.
The only difference is it's mesh density. One exports correctly and the other does not.
Try exporting a mesh higher than aprox. 3500 polys.
Added subscriber: @Taiseibutsu
Added subscriber: @OmarEmaraDev
Materials groups are exported correctly in my case. Did you confirm that by reimporting into Blender or another application?
Can you attach the obj you exported?
test_export_material_57651.obj
test_export_material_30594.obj
Here are the two exported files.
Please read line 62833 in test_export_material_30594 (Correct Export)
And compare it to line 121716 in test_export_material_57651
Changed status from 'Needs User Info' to: 'Needs Developer To Reproduce'
Okay, while material assignment is correct, groups seems to be incorrect by inspecting the file. As Taiseibutsu noted, the high density object have the following lines immediately after each other, which doesn't make sense, unless the
usemtl
are somehow expected to be used to infer the materials groups:Changed status from 'Needs Developer To Reproduce' to: 'Confirmed'
This issue was referenced by
eaef8d50bc
