Grease Pencil: Crash when trying to sculpt on object with Dot Dash modifier #102684
Closed
opened 2022-11-22 08:12:15 +01:00 by Sun Kim · 17 comments
Contributor
Operating system: Windows-10-10.0.19045-SP0 64 Bits
Graphics card: Radeon RX 570 Series ATI Technologies Inc. 4.5.0 Core Profile Context 22.11.1.221110
Broken: version: 3.5.0 Alpha, branch: master, commit date: 2022-11-21 01:31, hash: 7a6cdeb242
Worked: 3.0?
I'm not sure I can say it worked. While it doesn't crash sculpting still doesn't work as expected.
Blender crashes when I try to sculpt on Grease Pencil object with Dot Dash modifier.
Stroke.crash.txt
  • Add Grease Pencil Stroke, and add Dot Dash modifier to it
  • Switch to Sculpt mode
  • Try to sculpt on it
Stroke.blend
**System Information** Operating system: Windows-10-10.0.19045-SP0 64 Bits Graphics card: Radeon RX 570 Series ATI Technologies Inc. 4.5.0 Core Profile Context 22.11.1.221110 **Blender Version** Broken: version: 3.5.0 Alpha, branch: master, commit date: 2022-11-21 01:31, hash: `7a6cdeb242` Worked: 3.0? I'm not sure I can say it worked. While it doesn't crash sculpting still doesn't work as expected. **Short description of error** Blender crashes when I try to sculpt on Grease Pencil object with Dot Dash modifier. [Stroke.crash.txt](https://archive.blender.org/developer/F13959008/Stroke.crash.txt) **Exact steps for others to reproduce the error** * Add Grease Pencil Stroke, and add Dot Dash modifier to it * Switch to Sculpt mode * Try to sculpt on it [Stroke.blend](https://archive.blender.org/developer/F13959066/Stroke.blend)
Author
Contributor
Added subscriber: @persun
Member
Added subscriber: @lichtwerk
Member
Member
Can confirm, will check
Added subscriber: @antoniov
Can confirm too... I guess is the orig pointer is not set to NULL... testing.
Antonio Vazquez self-assigned this 2022-11-22 10:04:53 +01:00
This issue was referenced by 17fd81fb9b
This issue was referenced by 17fd81fb9be6a3705f161a79427dd6754f949a97
This issue was referenced by 8c82d4cbf6
This issue was referenced by 8c82d4cbf61b78bb0a52148a15912b870ece9f47
Member
Sculpting only works if the Edit Mode / show_in_editmode option is disabled.
I think there is a general issue with generative GP modifiers with the Edit Mode / show_in_editmode option: these show evaluated points that can be edited (as if an On Cage option - like the one for generative mesh modifiers - was enabled) but also e.g. the Dot Dash modifier does not draw the original stroke edit points at all anymore > so you cant actually use editmode with that modifier (and the show_in_editmode option). This all seems very wrong.
Then we also have the Subdivide modifier (which draws a mixture of original points - which can be edited - and evaluated points - which cannot be edited and draw in a different color -). Think this needs a general design of some sort.
> I'm not sure I can say it worked. While it doesn't crash sculpting still doesn't work as expected. Sculpting only works if the `Edit Mode` / `show_in_editmode` option is disabled. I think there is a general issue with generative GP modifiers with the `Edit Mode` / `show_in_editmode` option: these show evaluated points that can be edited (as if an On Cage option - like the one for generative mesh modifiers - was enabled) but also e.g. the `Dot Dash` modifier does not draw the original stroke edit points at all anymore > so you cant actually use editmode with that modifier (and the `show_in_editmode` option). This all seems very wrong. Then we also have the `Subdivide` modifier (which draws a mixture of original points - which can be edited - and evaluated points - which cannot be edited and draw in a different color -). Think this needs a general design of some sort.
Member
Regarding the crash: this broke between good e86c2f7288 and bad 7f4ee97b9e, will bisect if that helps.
Regarding the crash: this broke between good e86c2f728872 and bad 7f4ee97b9ef9, will bisect if that helps.
The generated points are always gray color, so these points are not editable. Anyway, this is something we want to revieww for GP 3.0.
Member
OK, 8c82d4cbf6 actually solved the issue of not being able to sculpt with the show_in_editmode option.
However, the following is not true (for the Dot Dash modifier):
These generated points are never drawn for this modifier.
In addition, using selection mask (of any type) is not working with this modifier.
@antoniov : want a new report?
OK, 8c82d4cbf6 actually solved the issue of not being able to sculpt with the `show_in_editmode` option. However, the following is not true (for the `Dot Dash` modifier): > In #102684#1449636, @antoniov wrote: > The generated points are always gray color, so these points are not editable. Anyway, this is something we want to revieww for GP 3.0. These generated points are never drawn for this modifier. In addition, using selection mask (of any type) is not working with this modifier. @antoniov : want a new report?
@lichtwerk This is a complex problem. The Modifier generates new points and we set the reference to the original points to allow the transformation, but to use Mask and to be drawn the point, it needs to be an original point. As the points are all evaluated, you cannot select them, so you cannot use any masking because its base in the selection.
> These generated points are never drawn for this modifier. @lichtwerk This is a complex problem. The Modifier generates new points and we set the reference to the original points to allow the transformation, but to use Mask and to be drawn the point, it needs to be an original point. As the points are all evaluated, you cannot select them, so you cannot use any masking because its base in the selection.
Member
It is not only an issue in sculptmode, editmode also does not draw any points to edit with this modifier (show_in_editmode ON)
> In #102684#1449676, @antoniov wrote: > @lichtwerk This is a complex problem. The Modifier generates new points and we set the reference to the original points to allow the transformation, but to use Mask and to be drawn the point, it needs to be an original point. As the points are all evaluated, you cannot select them, so you cannot use any masking because its base in the selection. It is not only an issue in sculptmode, editmode also does not draw any points to edit with this modifier (`show_in_editmode` ON)
Author
Contributor
Looks like this is not included in 3.3 updates or marked for backport?
Member
Added the fix to #100749 (Blender LTS: Maintenance Task 3.3) (not 100% sure it is backportable)
Reference: blender/blender#102684
