Measurit and measures ARCH #102932
Blender Cloud
Documentation
Eevee & Viewport
Import and Export
Rendering & Cycles
Add-ons (BF-Blender)
Add-ons (Community)
Reference: blender/blender-addons#102932
Operating system: macOS-13.0.1-x86_64-i386-64bit 64 Bits
Graphics card: AMD Radeon Pro Vega 64 OpenGL Engine ATI Technologies Inc. 4.1 ATI-4.9.48
Broken: version: 3.3.2 Release Candidate, branch: master, commit date: 2022-11-24 14:33, hash:
blender/blender@2124bfb211
Worked:
Dimensions don't show
Select default cube in either edit or object mode, press the Show button, Then segment
Based on the default startup
This is true whether show or hide in all its menus is selected{F13989454}
Added subscriber: @AlfredENeuman
Added subscriber: @OmarEmaraDev
In your screenshot, it doesn't seem like Show is actually pressed. Does pressing it change the icon to a pause icon?
No. It toggles between show and hide.
The button doesn't highlighted.
Can you open Blender from the terminal and check if any errors get printed to the terminal?
I do not know how to write the string to open Blender.
See https://docs.blender.org/manual/en/latest/advanced/command_line/launch/macos.html.
Used the terminal, opened Blender, no improvement. The terminal report:
Last login: Tue Dec 6 11:05:19 on ttys000
/Users/johnross/Documents/3D/Apps/Blender/3.32.app/Contents/MacOS/Blender ; exit;
johnross@Johns-iMac-Pro ~ % /Users/johnross/Documents/3D/Apps/Blender/3.32.app/Contents/MacOS/Blender ; exit;
Read prefs: /Users/johnross/Library/Application Support/Blender/3.3/config/userpref.blend
register_class(...):
Warning: 'panel.sp_node_editor_panel' does not contain 'PT' with prefix and suffix
Warning: 'panel.sp_node_editor_create_panel' does not contain 'PT' with prefix and suffix
Warning: 'panel.sp_node_editor_edit_panel' does not contain 'PT' with prefix and suffix
superimagedenoiser updater verbose is enabled
superimagedenoiser Updater: Read in JSON settings from file
BlendLuxCore 2.61alpha0 registered (with pyluxcore 2.6)
M_ARCH import modules
M_ARCH register
KeyError: 'bpy_prop_collection[key]: key "WinMan" not found'
Info: Updated sidebar tabs
fake_module: addon missing 'bl_info' gives bad performance!: '/Users/johnross/Library/Application Support/Blender/3.3/scripts/addons/bn_nodes.py'
In Object Mode
Added subscriber: @iss
Can't reproduce on:
Graphics card: AMD Radeon Pro 5700 XT OpenGL Engine ATI Technologies Inc. 4.1 ATI-4.9.48
Can you reset Blender to factory settings, enable only this addon, and see if you can reproduce the issue? File > Defaults > Load Factor Settings.
Unable to perform factory settings reset. Trying to enable factory settings, or disable or remove Prorender crashes Blender.
Downloading today's build repeats problem. Is there a file to remove from Blender contents which allow starting over?
You can remove
userpref.blend
file in~/Library/Application Support/Blender/3.3/
. Substitute3.3
with Blender version you are testing.Where is…/library/Application Support…? The one I find doesn't have Blender folder in it.
It should be in your home folder. There is probably system wide one, but I don't think it's used. I don't have much experience with Mac OS, so I use terminal when I am navigating on disk, so
is representing home folder.I repeat I did this for the original report but did it again Blender 3.3. Factory settings both Measurit and Measurit Arch. I guess I just can't use them since there is no solution.
I would recommend to check if this happens with Metal backend, which is available in 3.5. Download alpha build from https://builder.blender.org/download/daily/, go to Preferences > System > GPU Backend (not cycles render device) and chose Metal.
Other than that, I am not sure what could be done.
3.5, no joy. Until a Mac person finds a solution I just won't use either.
Thanks for checking.
