Renderer window gets stuck in 3.x - 2.9 is ok #102978
Closed
opened 2022-12-06 20:33:30 +01:00 by ion gion · 11 comments
Operating system: Manjaro Linux
Graphics card: 1080 TI
Broken: 3.3.1
Blender 3.3.1
build date: 2022-11-05
build time: 23:21:59
build commit date: 2022-10-04
build commit time: 18:35
build hash: b292cfe5a9
build platform: Linux
build type: Release
build c flags: -Wall -Werror=implicit-function-declaration -Werror=return-type -Werror=vla -Wstrict-prototypes -Wmissing-prototypes -Wno-char-subscripts -Wno-unknown-pragmas -Wpointer-arith -Wunused-parameter -Wwrite-strings -Wlogical-op -Wundef -Winit-self -Wmissing-include-dirs -Wno-div-by-zero -Wtype-limits -Wformat-signedness -Wrestrict -Wnonnull -Wabsolute-value -Wuninitialized -Wredundant-decls -Wshadow -Wno-error=unused-but-set-variable -Wimplicit-fallthrough=5 -march=x86-64 -mtune=generic -O2 -pipe -fno-plt -fexceptions -Wp,-D_FORTIFY_SOURCE=2 -Wformat -Werror=format-security -fstack-clash-protection -fcf-protection -flto=auto -fopenmp -std=gnu11 -msse -pipe -fPIC -funsigned-char -fno-strict-aliasing -ffp-contract=off -msse2
build c++ flags: -Wuninitialized -Wredundant-decls -Wall -Wno-invalid-offsetof -Wno-sign-compare -Wlogical-op -Winit-self -Wmissing-include-dirs -Wno-div-by-zero -Wtype-limits -Werror=return-type -Wno-char-subscripts -Wno-unknown-pragmas -Wpointer-arith -Wunused-parameter -Wwrite-strings -Wundef -Wformat-signedness -Wrestrict -Wno-suggest-override -Wuninitialized -Wundef -Wmissing-declarations -Wimplicit-fallthrough=5 -I /usr/include/python3.10 -fopenmp -msse -pipe -fPIC -funsigned-char -fno-strict-aliasing -ffp-contract=off -msse2
build link flags: -Wl,--version-script='/build/blender/src/blender/source/creator/symbols_unix.map'
build system: CMake
Worked: 2.90.0 Beta
The entire UI becomes unresponsive after the second rendering, no matter the renderer engine of choice.
Open blender - render the stage (even the default one) - First time it will work, then try to re-render again, the rendering window becomes stuck, UI is not responsive.
If left alone for a few minutes, it will unfreeze, but then again after trying a new render, it will still freeze.
In 2.90.0 Beta it all works properly.
**System Information** Operating system: Manjaro Linux Graphics card: 1080 TI **Blender Version** Broken: 3.3.1 Blender 3.3.1 build date: 2022-11-05 build time: 23:21:59 build commit date: 2022-10-04 build commit time: 18:35 build hash: b292cfe5a936 build platform: Linux build type: Release build c flags: -Wall -Werror=implicit-function-declaration -Werror=return-type -Werror=vla -Wstrict-prototypes -Wmissing-prototypes -Wno-char-subscripts -Wno-unknown-pragmas -Wpointer-arith -Wunused-parameter -Wwrite-strings -Wlogical-op -Wundef -Winit-self -Wmissing-include-dirs -Wno-div-by-zero -Wtype-limits -Wformat-signedness -Wrestrict -Wnonnull -Wabsolute-value -Wuninitialized -Wredundant-decls -Wshadow -Wno-error=unused-but-set-variable -Wimplicit-fallthrough=5 -march=x86-64 -mtune=generic -O2 -pipe -fno-plt -fexceptions -Wp,-D_FORTIFY_SOURCE=2 -Wformat -Werror=format-security -fstack-clash-protection -fcf-protection -flto=auto -fopenmp -std=gnu11 -msse -pipe -fPIC -funsigned-char -fno-strict-aliasing -ffp-contract=off -msse2 build c++ flags: -Wuninitialized -Wredundant-decls -Wall -Wno-invalid-offsetof -Wno-sign-compare -Wlogical-op -Winit-self -Wmissing-include-dirs -Wno-div-by-zero -Wtype-limits -Werror=return-type -Wno-char-subscripts -Wno-unknown-pragmas -Wpointer-arith -Wunused-parameter -Wwrite-strings -Wundef -Wformat-signedness -Wrestrict -Wno-suggest-override -Wuninitialized -Wundef -Wmissing-declarations -Wimplicit-fallthrough=5 -I /usr/include/python3.10 -fopenmp -msse -pipe -fPIC -funsigned-char -fno-strict-aliasing -ffp-contract=off -msse2 build link flags: -Wl,--version-script='/build/blender/src/blender/source/creator/symbols_unix.map' build system: CMake Worked: 2.90.0 Beta The entire UI becomes unresponsive after the second rendering, no matter the renderer engine of choice. **Exact steps for others to reproduce the error** Open blender - render the stage (even the default one) - First time it will work, then try to re-render again, the rendering window becomes stuck, UI is not responsive. If left alone for a few minutes, it will unfreeze, but then again after trying a new render, it will still freeze. In 2.90.0 Beta it all works properly.
Author
Added subscriber: @iongion
Author
Last text when running with debug
[RENDER]: BKE_object_select_update on OBwrProgress1 (0x7f6c1a44e438)
[RENDER]: BKE_object_data_select_update on MEwRing (0x7f6c21c3b838)
[RENDER]: BKE_object_select_update on OBwrBouble (0x7f6c1a44d838)
[RENDER]: BKE_object_data_select_update on MEwRing.002 (0x7f6c22406838)
[RENDER]: BKE_object_eval_local_transform on OBProgressIndicator.001 (0x7f6c1a44d238)
[RENDER]: BKE_object_eval_transform_final on OBProgressIndicator.001 (0x7f6c1a44d238)
[RENDER]: BKE_object_select_update on OBwrProgress2 (0x7f6c195b9638)
[RENDER]: BKE_object_data_select_update on MEwRing.003 (0x7f6c5a230838)
Depsgraph updated in 0.000827 seconds.
Depsgraph evaluation FPS: -nan
UI_menutype_draw: opening menu "DOPESHEET_MT_editor_menus"
UI_menutype_draw: opening menu "TIME_MT_editor_menus"
wm_window_make_drawable: set drawable 2
UI_menutype_draw: opening menu "IMAGE_MT_editor_menus"
Last text when running with debug ``` [RENDER]: BKE_object_select_update on OBwrProgress1 (0x7f6c1a44e438) [RENDER]: BKE_object_data_select_update on MEwRing (0x7f6c21c3b838) [RENDER]: BKE_object_select_update on OBwrBouble (0x7f6c1a44d838) [RENDER]: BKE_object_data_select_update on MEwRing.002 (0x7f6c22406838) [RENDER]: BKE_object_eval_local_transform on OBProgressIndicator.001 (0x7f6c1a44d238) [RENDER]: BKE_object_eval_transform_final on OBProgressIndicator.001 (0x7f6c1a44d238) [RENDER]: BKE_object_select_update on OBwrProgress2 (0x7f6c195b9638) [RENDER]: BKE_object_data_select_update on MEwRing.003 (0x7f6c5a230838) Depsgraph updated in 0.000827 seconds. Depsgraph evaluation FPS: -nan UI_menutype_draw: opening menu "DOPESHEET_MT_editor_menus" UI_menutype_draw: opening menu "TIME_MT_editor_menus" wm_window_make_drawable: set drawable 2 UI_menutype_draw: opening menu "IMAGE_MT_editor_menus" ```
Added subscriber: @iss
Does this happen with default cube? If not please upload .blend file.
Author
Yes, it is the default cube, if I can dig more, let me know what I should provide
Author
Just tried blender-3.4.0-linux-x64 and it behaves the same
Just tried `blender-3.4.0-linux-x64` and it behaves the same
Author
Maybe of any use, went ahead and actually tested all blender official bundles, these are actually downloaded from here https://download.blender.org/release/
  • blender-2.93.11-linux-x64
  • blender-3.0.0-linux-x64
  • blender-3.0.1-linux-x64
  • blender-3.1.0-linux-x64
  • blender-3.1.1-linux-x64
  • blender-3.1.2-linux-x64
  • blender-3.2.0-linux-x64
  • blender-3.3.1-linux-x64
  • blender-3.4.0-linux-x64
All of them fail to render the second time and freeze.
Now, what works
  • blender 3.3.1 from flatpak hub - works perfectly fine
  • Blender-v2.90.0-x86_64.AppImage - works perfectly fine
Hopefully of any help.
Maybe of any use, went ahead and actually tested all blender official bundles, these are actually downloaded from here https://download.blender.org/release/ - blender-2.93.11-linux-x64 - blender-3.0.0-linux-x64 - blender-3.0.1-linux-x64 - blender-3.1.0-linux-x64 - blender-3.1.1-linux-x64 - blender-3.1.2-linux-x64 - blender-3.2.0-linux-x64 - blender-3.3.1-linux-x64 - blender-3.4.0-linux-x64 All of them fail to render the second time and freeze. Now, what works - blender 3.3.1 from flatpak hub - works perfectly fine - Blender-v2.90.0-x86_64.AppImage - works perfectly fine Hopefully of any help.
Interesting... Since this is default startup file, I assume you render with eevee, not cycles. But if you have changed renderer and saved default file, check if you have enabled Performance > Persistent Data.
I thik, you may check if clicking on File > Defaults > Load Factory Settings would help.
Interesting... Since this is default startup file, I assume you render with eevee, not cycles. But if you have changed renderer and saved default file, check if you have enabled Performance > Persistent Data. I thik, you may check if clicking on File > Defaults > Load Factory Settings would help.
No activity for more than a week. As per the tracker policy we assume the issue is gone and can be closed. Thanks again for the report. If the problem persists please open a new report with the required information.
2 Participants
Reference: blender/blender#102978
