Sculpt: Paint tool cavity custom curve crash #103013
5 Participants
Reference: blender/blender#103013
Operating system: Windows 10
Graphics card: NVDIA RTX 2060 Super
Broken: 3.4, 3.5
Steps to reproduce the issue:
Enable Custom Curve under Advanced >> Cavity in the "Brush" dropdown
Result:
No Custom Curve is shown as in other Sculpting Tools & after trying to paint with the Paint tool setup this way blender instantly crashes.
Added subscriber: @Soudne
Sculpt Mode "Paint" tool cavity custom curve crashto Sculpt: Paint tool cavity custom curve crashAdded subscriber: @JosephEagar
I can't reproduce this.
Also cannot reproduce this.
Just checking if this is still an issue for you in recent builds from https://builder.blender.org/download/daily/ @Soudne @PratikPB2123 ?
Can still confirm in current main:
63f482d55091b12324d0b78a2f151083542ccd65
Call Stack
Still cant repro.a crash, @PratikPB2123 maybe you could check if these are properly called?
Crash is because
brush->automasking_cavity_curve
is null in some cases.So I added breakpoint inside
brush_blend_read_data
, the brush in that file hasbrush->automasking_cavity_curve
null itself 👀May not be bug in blender ig
Does this fix it?
Ah, wasnt aware this is about a particular file? (was just using the repro steps from my default startup file...)
Will check your fix. This is happening in default sculpting file btw.
Instead of assigning
, If I doautomasking->settings.cavity_curve = BKE_sculpt_default_cavity_curve();
then crash is prevented. But my knowledge is bit short here.btw brush is passed as const in
cache_init()
@farsthary might want to check
will reset to confirmed (since @PratikPB2123 is able to repro consistently).
And since this is a crasher, will also raise priority
@PratikPB2123 - Changing the automasking settings won't be a long term fix since it still means the user would be unable to edit the curve. That struct is just used as a cache of data.
My knowledge of how the blendfile reading / writing works is limited, but doesn't the order matter between the two methods? I'm not sure if this would be the root cause of the issue, but the order appears to be mismatched.
vs
This occurs specifically with the Sculpting
startup.blend
file. When that file is loaded, it doesn't have thePaint
brush which then means that thebrush_blend_read_data
for that block is never read that is supposed to initialize this value.
