Very bad UV "sphere projection" unwrap #103469
Reference: blender/blender#103469
Operating system: Windows-10-10.0.19044-SP0 64 Bits
Graphics card: NVIDIA GeForce GTX 1080/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 512.95
Broken: version: 3.4.1, branch: blender-v3.4-release, commit date: 2022-12-19 17:00, hash:
55485cb379
When a UV sphere is unwrapped using "sphere projection", the resulting layout doesn't make any sense: The poles create a layout that is very inefficient.
The outcome seems random (If I restart Blender and try again, the results do vary).
The outcome seem to depend on object rotation around Z, but it happens also if a clean file is opened, a UV sphere added, edited and immediately unwrapped, without ANY other operation.
The problem was reported back in 2013 already. It seems to be much better in 2.79 (only one triangle on top/bottom detached, what can be corrected easily), but it is bad to the point that UV layouts are useless {F14092531}in 3.3.0 and the latest version as well.
Start up Blender with a clean file, add a UV sphere, go to front-ortho, edit mode, select all, unwrap-> sphere projection
Added subscriber: @Fantasmo
Added subscriber: @Chris_Blackbourn
Confirmed in debugger.
Additional comment: The same problem seems to exist with sphere projection.
Hi @Fantasmo. I'm not seeing the distinction. Can you add some more detail?
Possible fix: D16869
p.s. I could also add an option to either "Pinch" (current behavior) or "Fan" (i.e. the default UV Sphere) the poles. Not sure if that would be here, or if that would go through right-click-select ?
There is no distinction between the sphere projection and the cylinder projection, both show the same erratic behavior.
I wanted to make sure that the cylinder projection is checked as well, while you are at it, as it possibly needs the same fix.
"Fan" imho. makes the better UV layout.
Ah, good spotting! Have patched Cylinder project as well as added a "Fan" option.
Let us know if you need a sneak-build for testing...
No sneak-build needed, thank you.
I am confident that you guys have that under control and will have a look at the next official release.
Thanks for all what you are doing!
A final question though? Does the new solution respect existing marked seams? This would be great!
I don't quite see how the existing seams would change the layout. Both the sphere and cylinder projection specify the UVs everywhere except the poles.
Perhaps you could mock-up a screenshot of a with/with-out seams layout?
Its not about changing the layout, only "where the unwrap starts".
Currently, the default sphere unwrap "starts" at the backside of the sphere and wraps around it, completely ignoring seams.
In 3D modelling we want to control the seam location however, as there often are texture artefacts. So the ideal location may be elsewhere than the backside.
So it would be nice if the unwrap would start at that seam and not the backside of the sphere / cylinder, like the default unwrap that has not seams to rely on.
Granted, I can identify the location of the map edge and rotate the object, to move the "invisible" seam where I need it, but this is counter-intuitive and merely a workaround.
It would be better if the unwrap started at the seam, if there is a "pole to pole"-seam.
Users are used to the following workstream:
Wow, that's a fascinating idea.
Such a thing should be possible, however the code change is a little non-obvious.
Just as a procedural matter, I might get the current fix committed (which will close the task), and then investigate an extension to respect seams.
This issue was referenced by
280502e630
Changed status from 'Resolved' to: 'Needs Developer To Reproduce'
Reopen to see if "Seam" unwrap is possible.
Heyas @Fantasmo !
Seam support is now in
main
and will most likely be in the next nightly build.Would you be able to download the next nightly when it becomes available and confirm if everything is working correctly for both UV Sphere Project and UV Cylinder Project?
Thanks!
