Animation Editors Paper Cuts #103855
Closed
opened 2023-01-13 10:32:16 +01:00 by Christoph Lendenfeld · 30 comments
The goal of this design task is to identify small tweaks that can improve the user experience for the following editors: Graph Editor, Dope Sheet, Timeline.
The important word is small. We are not trying to solve underlying issues here, just polish what we have.
Drivers and the NLA editor are excluded from this since they are a whole separate beast.
Previous Design Tasks for inspiration
Graph Editor
Channels
  • Pin individual channels. At the moment only the object itself can be pinned. It is often useful to pin a single channel, e.g. Translate X. (Not easy to change, the pinning flag is store on the FCurve. Would need a bigger refactor of the channel box)
  • Add filter for "Only Pinned Channels" (The filtering code is complicated and will be overhauled, not in scope for papercuts)
  • Add filter for "Only Armatures in Pose Mode".
  • Add right click option "Frame Channel". Similar to "Frame Selected" for keyframes #104523
  • Add ALT+MMB hotkey when clicking on a channel to frame the keyframes in that channel. Similar to ALT+MMB in the viewport focuses to whatever is under the cursor. #104523
  • Allow editing of selected keyframes in the N panel instead of only the active (Taken off the list because it is working with the ALT key. A proper selection-edit is discussed here #54862 . While the current state is not ideal, it is too much for a papercut)
  • Shift click to expand selection like in the Outliner. Atm it is the equivalent of Ctrl-Click [D17079](https://archive.blender.org/developer/D17079) / #104565
  • Enable Box Select just like in the Outliner #104505
  • When selecting an object, the channels should be uncollapsed
  • Shift click the arrows to expand/collapse all children deceptively simple, but the arrow is a button directly linked to a flag. There is no easy way to change that atm.
  • Allow multi editing for FCurve modifiers
  • Ability to name them D17142 / #104949
  • Right click menu in Channels to add FCurve modifiers to selection D17066
Menu Options
  • Move "Only selected curve keyframes" option to user preferences #104532
  • Move "Use High Quality Display" option to user preferences #104532
Key Manipulation
  • copy/paste key values relative to current value of the channel #104512
  • option to lock key movement to only 1 axis. Like pressing G and it is already locked to the Y axis (needs design task)
  • Remove drawing of keyframes on locked curves #104561
  • Option to change curve display for certain channel types, e.g. make rotation channels dashed (needs a design task first #104867 )
  • Keyframe handles stay selected when key is deselected (needs design task)
  • Indicate locked axis when manipulating keys, Like in the 3D viewport where you can see a blue line when you do G+Z (needs design task)
  • Insert keyframe only on the active curve #106307
Misc
  • Add GUI to quickly access slider operators like "Blend to Neighbor" and "Breakdown" #104530
  • Playhead snapping options. E.g. snap to closest keyframe while scrubbing to make sure you are on a key (Will get its own design task)
  • Only Graph Editor and Driver editor have a right margin: D17102 (Not actually an issue since the scrollbar is in different places)
  • when hitting "normalize" set the y extents of the view to 1/-1 #105857
  • Draw area outside of normalization range darker #106302
Dope Sheet
  • Add pinning options to the Dope Sheet. Pinning is respected in the Dope Sheet, but there is no way to change it since the button is missing. D17061
  • Make sure scrolling vertically doesn't go off the top end of the view, also happens on the timeline #104516
Time Line
  • key shape isn't represented in the timeline Devtalk (taken off the list because after a discussion in the A&R meeting we came to the conclusion that the timeline shouldn't be a dope sheet)
Drivers
  • add random(seed, time) function Example (Out f scope for this task, but can be picked up later)
The goal of this design task is to identify small tweaks that can improve the user experience for the following editors: **Graph Editor, Dope Sheet, Timeline**. The important word is **small**. We are not trying to solve underlying issues here, just polish what we have. Drivers and the NLA editor are excluded from this since they are a whole separate beast. **Previous Design Tasks for inspiration** * Improvements to Curve Modifiers (Animation Curves) - #86179 * Improve usability of Group Colors in animation editors - #81744 * More frame snapping options - #91973 * RCS about snapping https://blender.community/c/rightclickselect/P0bbbc/?sorting=hot # Graph Editor **Channels** - ~~Pin individual channels. At the moment only the object itself can be pinned. It is often useful to pin a single channel, e.g. Translate X.~~ (Not easy to change, the pinning flag is store on the FCurve. Would need a bigger refactor of the channel box) - ~~Add filter for "Only Pinned Channels"~~ (The filtering code is complicated and will be overhauled, not in scope for papercuts) - ~~Add filter for "Only Armatures in Pose Mode".~~ - [x] ~~Add right click option "Frame Channel". Similar to "Frame Selected" for keyframes #104523~~ - [x] ~~Add ALT+MMB hotkey when clicking on a channel to frame the keyframes in that channel. Similar to ALT+MMB in the viewport focuses to whatever is under the cursor. #104523~~ - ~~Allow editing of selected keyframes in the N panel instead of only the active~~ (Taken off the list because it is working with the ALT key. A proper selection-edit is discussed here #54862 . While the current state is not ideal, it is too much for a papercut) - [x] ~~Shift click to expand selection like in the Outliner. Atm it is the equivalent of Ctrl-Click [D17079]~~(https://archive.blender.org/developer/D17079) / #104565 - [x] ~~Enable Box Select just like in the Outliner~~ #104505 - [ ] When selecting an object, the channels should be uncollapsed - ~~Shift click the arrows to expand/collapse all children~~ deceptively simple, but the arrow is a button directly linked to a flag. There is no easy way to change that atm. **Modifiers** - [x] Allow multi editing for FCurve modifiers - [x] ~~Ability to name them [D17142](https://archive.blender.org/developer/D17142) / #104949~~ - [x] ~~Right click menu in Channels to add FCurve modifiers to selection [D17066](https://archive.blender.org/developer/D17066)~~ **Menu Options** - [x] ~~Move "Only selected curve keyframes" option to user preferences #104532~~ - [x] ~~Move "Use High Quality Display" option to user preferences #104532~~ **Key Manipulation** - [x] ~~copy/paste key values relative to current value of the channel #104512~~ - ~~option to lock key movement to only 1 axis. Like pressing G and it is already locked to the Y axis~~ (needs design task) - ~~Remove drawing of keyframes on locked curves~~ #104561 - ~~Option to change curve display for certain channel types, e.g. make rotation channels dashed~~ (needs a design task first [#104867](https://projects.blender.org/blender/blender/issues/104867) ) - ~~Keyframe handles stay selected when key is deselected~~ (needs design task) - ~~Indicate locked axis when manipulating keys, Like in the 3D viewport where you can see a blue line when you do G+Z~~ (needs design task) - [x] ~~Insert keyframe only on the active curve~~ [#106307](https://projects.blender.org/blender/blender/pulls/106307) **Misc** - [x] ~~Add GUI to quickly access slider operators like "Blend to Neighbor" and "Breakdown" #104530~~ - ~~Playhead snapping options. E.g. snap to closest keyframe while scrubbing to make sure you are on a key~~ (Will get its own design task) - ~~Only Graph Editor and Driver editor have a right margin: [D17102](https://archive.blender.org/developer/D17102)~~ (Not actually an issue since the scrollbar is in different places) - [x] ~~when hitting "normalize" set the y extents of the view to 1/-1~~ [#105857](https://projects.blender.org/blender/blender/pulls/105857) - [x] ~~Draw area outside of normalization range darker~~ [#106302](https://projects.blender.org/blender/blender/pulls/106302) # Dope Sheet - [x] ~~Add pinning options to the Dope Sheet. Pinning is respected in the Dope Sheet, but there is no way to change it since the button is missing. [D17061](https://archive.blender.org/developer/D17061)~~ - [x] ~~Make sure scrolling vertically doesn't go off the top end of the view, also happens on the timeline #104516~~ # Time Line - ~~key shape isn't represented in the timeline~~ [Devtalk ](https://devtalk.blender.org/t/animation-editors-paper-cuts/27263/28?u=christophlendenfeld) (taken off the list because after a discussion in the A&R meeting we came to the conclusion that the timeline shouldn't be a dope sheet) ~~Drivers~~ - ~~add random(seed, time) function [Example](https://developer.blender.org/rBf8cc01595d1181b9a8adcb6aa930d4cbfebdc8bf) (Out f scope for this task, but can be picked up later)~~
Author
Member
Author
Member
Added subscribers: @ChrisLend, @LucianoMunoz
Added subscriber: @AndyCuccaro
" Add filter for "Only Armature in Pose Mode". "
I hope this is "Only Armatures... " because I think it should filter to however many armatures are set to pose mode at the time allowing you to filter down to multiple rigs or characters
" Add filter for "Only Armature in Pose Mode". " I hope this is "Only Armatures... " because I think it should filter to however many armatures are set to pose mode at the time allowing you to filter down to multiple rigs or characters
I think we should add:
"frame the range"
Currently we can only frame either the entire area where you have keys or just the selection, but not the "range" set for the shot nor the "preview range"
and framing the range you've set for working is more often than not what you want since you normally would work on shots that are a couple to a few hundred frames.
And if you want to work on a part of a shot you'd normally set the preview range.
So having a way to quickly zoom to the range is a timesaver, and this applies to all animation editors including the Timeline, DopeSheet, Graph Editor, NLA, VSE.
I think we should add: "frame the range" Currently we can only frame either the entire area where you have keys or just the selection, but not the "range" set for the shot nor the "preview range" and framing the range you've set for working is more often than not what you want since you normally would work on shots that are a couple to a few hundred frames. And if you want to work on a part of a shot you'd normally set the preview range. So having a way to quickly zoom to the range is a timesaver, and this applies to all animation editors including the Timeline, DopeSheet, Graph Editor, NLA, VSE.
Author
Member
Yes, of course it can be more than 1 armature.
Regarding "frame the range"
it is kind of possible using the Numpad . key or View->Frame Selected, all while having nothing selected.
but I assume you are talking about that option without losing your selection
> In #103855#1473758, @LucianoMunoz wrote: > " Add filter for "Only Armature in Pose Mode". " > I hope this is "Only Armatures... " because I think it should filter to however many armatures are set to pose mode at the time allowing you to filter down to multiple rigs or characters Yes, of course it can be more than 1 armature. Regarding "frame the range" it is kind of possible using the Numpad . key or View->Frame Selected, all while having nothing selected. but I assume you are talking about that option without losing your selection
Yeah without losing the selection,
That function works like that because when you have nothing selected the only place to refer back to is the frame range, but thats pretty useless because when you have no keys there aren't many reasons to move the timeline zoom around.
Also that doesnt apply to the preview range, only to the scene range.
Yeah without losing the selection, That function works like that because when you have nothing selected the only place to refer back to is the frame range, but thats pretty useless because when you have no keys there aren't many reasons to move the timeline zoom around. Also that doesnt apply to the preview range, only to the scene range.
Added subscriber: @lesballs_2.0
Member
Added subscriber: @zNight
Member
Added subscriber: @BClark
Added subscriber: @Slowwkidd
Member
Menu Options
Hi, do you have any keys in mind for both properties.
> Menu Options Hi, do you have any keys in mind for both properties.
Member
Hi, implemented range selection here: D17079: Allow select range in animation editor
Patch is still in WIP (works only with fcurves so far)
Will include other channel types too. Which other channel types are expected to do range selection?
> Shift click to expand selection like in the Outliner. Atm it is the equivalent of Ctrl-Click Hi, implemented range selection here: [D17079: Allow select range in animation editor](https://archive.blender.org/developer/D17079) Patch is still in WIP (works only with fcurves so far) Will include other channel types too. Which other channel types are expected to do range selection?
Author
Member
In #103855#1477787, @PratikPB2123 wrote:
Menu Options
@PratikPB2123 what do you mean by that?
But really cool that you started work on the range selection. Ideally it will work with anything, but I know that's a bit more difficult. I had a look at that as well, and the selection state is stored on the data which is annoying.
> In #103855#1477787, @PratikPB2123 wrote: >> Menu Options > Hi, do you have any keys in mind for both properties. @PratikPB2123 what do you mean by that? But really cool that you started work on the range selection. Ideally it will work with anything, but I know that's a bit more difficult. I had a look at that as well, and the selection state is stored on the data which is annoying.
Member
@ChrisLend hi, I was asking about default shortcut keys for "Only selected curve keyframes" and "Use High Quality Display" options
I dont think those would need hotkeys, those properties should be moved to blender preferences.
Member
@ChrisLend , maybe we can edit this and change it to "add scroll bar" or create a separate point for scrollbar?
> Only Graph Editor and Driver editor have a right margin: [D17102](https://archive.blender.org/developer/D17102) @ChrisLend , maybe we can edit this and change it to "add scroll bar" or create a separate point for scrollbar?
Author
Member
@PratikPB2123 first of all thanks for looking into this. And yes adding the scrollbars in the same patch would make a lot of sense. I noticed that as well when I was looking into it, but unfortunately I couldn't find where the scrollbars are added
> In #103855#1479645, @PratikPB2123 wrote: >> Only Graph Editor and Driver editor have a right margin: [D17102](https://archive.blender.org/developer/D17102) > @ChrisLend , maybe we can edit this and change it to "add scroll bar" or create a separate point for scrollbar? @PratikPB2123 first of all thanks for looking into this. And yes adding the scrollbars in the same patch would make a lot of sense. I noticed that as well when I was looking into it, but unfortunately I couldn't find where the scrollbars are added
Added subscriber: @JerBot
Christoph Lendenfeld was assigned by Sybren A. Stüvel 2023-01-27 10:37:03 +01:00
Member
Modifiers: Ability to name them
D17142: Allow renaming F-curve modifier
> Modifiers: Ability to name them [D17142: Allow renaming F-curve modifier](https://archive.blender.org/developer/D17142)
Added subscriber: @AdamEarle
Keyframe-type colors are not reflected in the menu when updated. I know that this is only minor, but it would be super great if the menu did reflect the changes in the menu. We use red as selected keys because it just makes the day better when you are animating with a clear read on the keys the user has selected.
blender_jzeHwnTSDP.mp4
Keyframe-type colors are not reflected in the menu when updated. I know that this is only minor, but it would be super great if the menu did reflect the changes in the menu. We use red as selected keys because it just makes the day better when you are animating with a clear read on the keys the user has selected. [blender_jzeHwnTSDP.mp4](https://archive.blender.org/developer/F14231872/blender_jzeHwnTSDP.mp4)
Added subscriber: @ndh
Philipp Oeser removed the
label 2023-02-09 14:34:41 +01:00
Sybren A. Stüvel added this to the Compositing project 2023-02-09 16:55:27 +01:00
Sybren A. Stüvel modified the project from Compositing to Animation & Rigging 2023-02-09 16:55:30 +01:00
@ChrisLend hi,a question please is there a way to move a channel to an existing groupe ? or it will be added ? and can be by selecting and dragging it to a groupe if possible ? thanks
Author
Member
@hamza-el-barmaki not possible right now but it's something that's being looked into. It won't be soon though
I wonder since the timeline doesnt have an option to Only show the selected object's keys like the dopesheet does, if it maybe should always show all keys in the scene (or at least default to that), it's always weird to me to have to switch from timeline to dope sheet just to change that option when I need to do global timing changes in a scene.
Blender Bot added
and removed
labels 2023-03-30 19:31:06 +02:00
Blender Bot added
and removed
labels 2023-03-30 19:31:35 +02:00
Sorry, that comment and close button is dangerous ! xD
Author
Member
haha yeah that button is dangerous
maybe we should think about a complete redesign of the timeline then, how to make it useful and unique but not the dope sheet
haha yeah that button is dangerous maybe we should think about a complete redesign of the timeline then, how to make it useful and unique but not the dope sheet
Author
Member
thanks for all the ideas, I consider this task finished now.
Not all things I looked at could be implemented easily, that doesn't mean they are off the table, just that they are more work than could be considered a papercut.
e.g. multi editing fcurve modifiers will come at some point
thanks for all the ideas, I consider this task finished now. Not all things I looked at could be implemented easily, that doesn't mean they are off the table, just that they are more work than could be considered a papercut. e.g. multi editing fcurve modifiers will come at some point
Blender Bot added
and removed
labels 2023-04-13 15:35:00 +02:00
Sybren A. Stüvel removed this from the Animation & Rigging project 2023-05-04 09:18:02 +02:00
12 Participants
Reference: blender/blender#103855
