Python: Add deprecation warnings to GPUBatch program usage. #103978
Closed
opened 2023-01-18 19:11:11 +01:00 by Jeroen Bakker · 14 comments
Member
Calls to gpu.types.GPUBatch.draw#program without a program parameter, or a None as value of the program parameter should raise a deprecation warning.
All calls to gpu.types.GPUBatch.program_set should raise a deprecation warning..
Check pygpu_batch__tp_new how to raise a deprecation warning using CPython.
It would be great if you want to work on this topic. If so, assign the task to yourself. If you have questions or require some guidance, please get in contact via #blender-coders or via a reply on this task.
Calls to `gpu.types.GPUBatch.draw#program` without a program parameter, or a None as value of the program parameter should raise a deprecation warning. All calls to `gpu.types.GPUBatch.program_set` should raise a deprecation warning.. Check `pygpu_batch__tp_new` how to raise a deprecation warning using CPython. It would be great if you want to work on this topic. If so, assign the task to yourself. If you have questions or require some guidance, please get in contact via #blender-coders or via a reply on this task.
Author
Member
Author
Member
Added subscriber: @Jeroen-Bakker
Added subscriber: @Jash-Shah
Jash Shah self-assigned this 2023-01-29 18:46:18 +01:00
Hey, I am new to Blender dev, but this task seems like a good place for me to start since I have some experience working with CPython before!
As mentioned in the task description, I'm assigning the task to myself.
Hey, I am new to Blender dev, but this task seems like a good place for me to start since I have some experience working with CPython before! As mentioned in the task description, I'm assigning the task to myself.
Philipp Oeser removed the
label 2023-02-09 15:11:54 +01:00
Contributor
hey, is this issue still open ??
Author
Member
I think so, I haven't seen any activity on this.
Contributor
@Jeroen-Bakker could you guide me to pygpu_batch__tp_new program so i could learn how to raise a depreciation warning
Contributor
nvm found it
nvm found it
Author
Member
It is better to ask specific code questions on blender.chat in the blender-coders channel. You can expect quicker response there, as there are more developers present to help you with your questions.
Contributor
@Jeroen-Bakker i did some changes in the gpu.py.bacth file i'm attaching the file here could you see through it once and tell me the necessary changes i would have to do
Author
Member
@Prakhar-Singh-Chouhan Can you upload it as a pull request? That makes it easier to use review tools provided here.
Hi. Is it available for me to work on? If so, I'd like to take it up.
Author
Member
Think so. please refer to the #105295 as it already provides a solution, but needs to be updated and review comments needs to be solved.
Contributor
@Jeroen-Bakker I updated the PR and solved the review comments. Can you have a look at it #117299
@Jeroen-Bakker I updated the PR and solved the review comments. Can you have a look at it https://projects.blender.org/blender/blender/pulls/117299
Blender Bot added
and removed
labels 2024-03-04 08:34:44 +01:00
Jeroen Bakker added this to the 4.2 LTS milestone 2024-03-04 08:34:53 +01:00
Jeroen Bakker added this to the Python API project 2024-03-04 08:35:03 +01:00
Jash Shah was unassigned by Jeroen Bakker 2024-03-04 08:35:29 +01:00
Reference: blender/blender#103978
