Updated Matcaps with specular layer #104285
5 Participants
Reference: blender/blender#104285
(NOTE) This task is part of the community & sub tasks of the workboard. Anyone is free to pick up this task and contribute. For any questions or needed reviewers, please tag @JulienKaspar.
Specular lighting has been supported for Matcaps for years now, but the current set of Matcaps has never been updated to use the feature.
This is done by using multilayer .exr files and saving it with two layers, named
diffuse
andspecular
respectively.The
specular
layer is then automatically added instead of multiplied onto the shading.The goal is to provide an updated set of multilayer .EXR files and the original files in which they were created (ideally .blend).
@DanielBystedt Previously already worked on this updated set and shared his progress here:
These can be used as a starting point.
matcaps Bystedt 210203-20230201T171808Z-001.zip
This task is not about adding new matcaps or removing/replacing existing parts of the set, although this can be discussed.
Once the .blend file is assembled, it can be stored at:
https://svn.blender.org/svnroot/bf-blender/trunk/lib/resources/
Added subscribers: @JulienKaspar, @DanielBystedt, @JosephEagar
Some notes about the provided zip:
Added subscriber: @wevon-2
A Cast/Sphere Modifier with Factor=1, after Subdivision, would make the ball completely spherical. Although it may seem so, it is not by a little, and the poles are slightly pointed.
Also important note: There was already a call for content for this purpose and many contributors provided updated or new matcaps.
https://devtalk.blender.org/t/call-for-content-matcaps-source-file/
Hi!
I remember that we discussed creating new matcaps as well, so I'll post the ones I made around 2 years ago in this post
Matcap HDRI and blender render file
Bystedt matcaps 210228.zip
Matcap previews
Matcap examples in viewport
Bystedt matcap testrenders 210301.rar
Some important notes from the devtalk thread.
Some of those don't have .blend files attached so this needs to be done again from scratch.
Zebra matcaps make selections hard to see. Should probably be colored instead:
Clay_brown matcap can be improved to have more gradients in the shadows:
The carpaint matcaps need subtle noise added to clearly read surface curvatures in detail:
Here are also various donations from the devtalk thread. Some don't have .blend files attached but can be used as direct reference for creating new matcaps.
Some are also updated versions of the current matcaps by the original authors.
matcaps_donations.zip
I created #104640 with some thought on what should be a step forward into better handling the material system with matcap lighting.
It kind of overlap this task. To me, we should take the time to make sure we update matcaps once and for good.
@fclem I don't thnkk we should support metalic and roughness sliders for matcaps. The strength of the matcaps is that they are specific and consistent in their look. That is always at the cost of flexibility.
I also don't think users would want to manually assign a new material to objects and tweak the metallic and roughness factor to get a good metallic matcap look. They'd just instead pick an out-of-the-box metal matcap.
I do agree that we should make the matcaps more color neutral though.
That will make them easier to use when already using material/attribute colors.
The matcaps also definitely need some manual work and tweaking for the correct look. So an automatic conversion seems unnecessary.
Well, splitting specular layer increased their flexibility. Not
I do agree. That's why I want the single color mode to reflect what the matcap looks in the matcap preview.
Well my issue is more with scenes or objects with multiple material. For many reasons. It would be better to have 1 lighting condition for all. Having to pick matcaps per materials seems like really bad for managing the lighting which should be decoupled from materials. Not to mention about the technicality of it (potentially unlimited number of matcap per scene). But I guess users think more of matcaps as material definition, not lighting condition (which are both true).
I do acknowledge that I might have been overzealous on this one. I have prioritize the consistency of the features (material system + Lighting system) over complexity of implementation and usability. But I'm sure, by refining the idea, we can come up with a simpler system that (while not perfect) might be better than what we have.
Hi.
I am not sure about adding noise linearly.
The point is that there are two functional types of matcaps
artistic, that make model pleasant looking in viewport and usually represent some existing material.
and technical, that may be sufficiently harder on eyes, but allow to read specific surface properties, including spotting tiny issues by amplifying them (zebra shader, black overcontrast shader, noisy matcaps, matcaps with specific gradients and flares).
Matcaps with deep shadow spot are suitable for for sculpting (since provide additional visual depth information), matcaps without deep shadow spot are suitable for modeling, (since absence of a shadow spot allow to work with black wireframes)
The problem is that technical matcaps are usually has to be properly engineered to match workflow specifications, and it is not possible to turn artistic matcap into technical vithout losing visual appearance accuracy, so it probably has to be two separate carpaint shaders - artistic one for nice hardsurface result visual appearance and technical one with horizontal flare and noisy gradiented speckles for checking curvature during hardsurface modeling.
Im also not sure about coloring technical matcaps, since indeed matcaps can be used with overlayed material colors, it is reasonable to leave it monochrome but make less contrast to have the ability to see black and white (active selected and not selected) wireframes. Also it is reasonable to enlarge the number of stripes in zebra matcap x2 times.
