two problems with explode modifier and vertex group
Group: current SVN version
Resolution: Fixed
1) If you assign a vertex group to an "explode modifier" you can't delete it or change your mind. The only solution is by deleting the explode modifier or to delete the vertex group. There is no menu entry "none".
2) If you have several vertex group in the "Links and Material panel" and one of these vertex group assigned to the explode modifier : if you delete the vertex group assigned to the explode modifier, the next vertex group in the list is automatically assigned to the explode modifier rather than leave a blank area (or none)
(video)
windows svn, revision 14742
This task was automatically closed as archived as part of migration, because the project or tracker this task belonged to is no longer active.
