Armature documentation (web page) error/enhancement
this is coming from a really newb perspective and is a very picky comment, but:
this page http://www.blender.org/documentation/245PythonDoc/Armature-module.html the first example should be simpler, as it tries to edit all armatures in the file etc. I would suggest that it be replaced by:
have the comment that it edits all existing armature, and that you should run the armature creation script on this page http://www.blender.org/documentation/245PythonDoc/Pose-module.html first from an empty scene, so that an armature with a bone.003 exists.
then, on the Armature-module.html page, the example should begin:
# start with a new blend file and run the first example script on Pose-module.html to create a 4-bone armature: http://www.blender.org/documentation/245PythonDoc/Pose-module.html
# this example shows you how to edit that armature
import Blender
from Blender import *
arm = Armature.Get('myArmature')
if True:
arm.drawType = Armature.STICK #set the draw type
arm.makeEditable() #enter editmode
#generating new editbone
... (the rest works just fine)
