Group: V 2.47 release
Resolution: New
Category: Tools
Vista Home Premium SP1 64
AMD Athlon 64 X2 5600+ @2.8GHz
Nvidia Geforce 8800GTX with 177.92 beta drivers
6142MB RAM
Blender 2.47 final
Hey there,
When the occlude background geometry function is on, it is still possible to select occluded faces when using the select brush with intersecting meshes.
e.g. When mesh a is intersected by mesh b, the occluded faces of mesh b are still selectable through mesh a even though they are not visible.
(i realise the partially visible faces should be selected :) )
1. Select the chain_lp mesh and go to edit mode whilst ensuring the occlude background geometry is on
2. Enable the brush select by double tapping b
3. select the chain_lp with the brush
4. Rotate the mesh so the previously occluded faces are visible
5. Faces which were occluded are selected
I have made a video of this problem here
http://www.metalliandy.com/blender/unseen_faces/unseen_faces.htm
Thanks for the help :)
