Math node, fixes cleanup and sqrt #17917
7 Participants
Reference: blender/blender#17917
%%%Hi,
I added sqrt to the math composite node, because I needed it for stuff like this:
http://atommuell.mum.jku.at/~aurel/sobel_filter_suz.png
http://www.blenderstorm.org/qapoll/ideas/idea/683/
I also found a bug in the pow function, it couldn't raise negative values at all. When I tried to fix this i ran into another problem, see BugID 17915. I did a workaround for the math node at the moment tho.
Because the code was rather unreadable too, I cleaned it up a bit. However, I doubt that this 2-4_pixel_processor functions are really a good idea, it might be a little bit more structured code, but it slows down computation massively, compared to just a loop over all pixels. Another issue atm is the labeling in the GUI of the node, it's really not intuitive which input is which variable in operations like x-y, x^y, sin(x),... It might be better to name the inputs X and Y and put names like "sqrt(x)", "x+y" in the drop down box.
Aurel
%%%Ok, here's an update, i completely ignored the fact, that the state of an input button is saved to a blend file. In the GUI i added sqrt right to next and changed the other ids, to correspond with the order of the gui. This of course breaks downwards compatibility.
I also changed all the sinf(float),logf,.. functions to the C90 standardized sin(double),... I often here arguments, to stay C90 compliant, which is in most cases a bad idea in the year 2008, but I am not to sure about sinf()
new patch added.%%%
%%%The cleanup seems pretty good. However, I have a couple of issues.
The pow case shouldn't allow negative numbers to be raised by non-integer powers because that results in imaginary numbers. For example, -4^0.5 = 2i
You should put in checks for those cases to prevent the pow function from returning an error.
The sqrt case is redundant functionally, because you can accomplish the same thing using pow:
a^0.5 == sqrt(a)
There may be a performance advantage in using an explicit sqrt, so I'm not against adding it per-se. But just keep it in mind.%%%
%%%1) Well, that was the fix in the first place. The original code doesn't raise negative numbers at all, now they are raised by integers, or rounded non integers, if closer than 0.001 to an integer (due to this great features of the value button, that needs fixing anyway). Otherwise the result is 0. Maybe you have overlooked that.
%%%Ack! You are right. Somehow when I looked at the patch last time I thought all you did was remove the existing (overly conservative) check. I have no idea why, as the code is quite blatant. My apologies.
Regarding the sqrt: I guess the issue for me is just that it feels a little too specific/limited to me. I would feel more comfortable with an n-root operation, for example. But perhaps that's just me. It's a minor quibble in any case.%%%
%%%OK... I don't speak english math well... 'raise' is in programming language also used as 'return', so I thought you meant the issue was about the math node not returning negative values at all!
However, the patch still doesnt solve it, it only has a comment about "inaccurate float". Floats are nearly always inaccurate... just proper rounding should solve it. int(y+0.5);
%%%Rounding, that's what the patch does:
if ( x > 0 ) {
} else {
Really, just an annoying little thing,.... By now this also has to be changed in the copy of the Math Texture Node.%%%
%%%Hi, trying to update the status of the patch tracker. Please respond if this patch is still viable/useful and needs review or if it can be closed.%%%
%%%Hi Tom I just starting to study some patches to reach a better idea on how blender code works.
I'll be very grateful if you update the status of this patch. Does it still works?
Thanks
Paolo%%%
Is this still valid? If not I am gonna close this.
Power is ok, root is not present, code has still strange architecture which is ridiculous unefficient. I think you can close this one.
Could you elaborate what you mean with "strange architecture"? :)
If there is something we can improve, I am all ears.
Time to archive.
