Edge filter node has shifted output.
Group: current SVN version
Resolution: Fixed
Category: Compositor
The output when using a "value" input seems 1 pixel shifted to the left compared the correctoutput (wich can be obtained by coverting to image type before filter).
Confirmed by dfelinto on #blendercoders
Xavier, was this patch implemented yet?
If not I would suggest you to email bf-comitters list or ask for a developer with commit access to take a look at it.
I by implemented you meen in svn then no, it is not.
Thanks fo the advise, I will do it.
xa
thanks for fix, is in svn now!
Ton Roosendaal (ton) changed the task status from Unknown Status to Unknown Status.Dec 15 2008, 9:38 AM
This task was automatically closed as archived as part of migration, because the project or tracker this task belonged to is no longer active.
