(2.5) blender uses deprecated 'strstream' STL class, causes warnings with gcc
Closed, InvalidPublicPATCH
I am using blender 2.5 from SVN (revision 22463) and I get a compilation warning:
"This file includes at least one deprecated or antiquated header. Please consider using one of the 32 headers found in section 17.4.1.2 of the ++ standard. Examples include substituting the <X> header for the <X.h> header for C++ includes, or <iostream> instead of the deprecated header iostream.h>. To disable this warning use -Wno-deprecated."
I am using gcc 4. The problem seems to be that source/gameengine/VideoTexture/Exception.cpp includes <strstream> and uses 'ostrstream' objects which are considered obsolete.
Attached there is a patch that use 'ostringstream' objects, removing a lot of potential problems related to the obsolete STL 'strstream' class.
Hope to be useful.
Mauro Toffanin
p.s.: there aren't <strstream> declarations in the source code other than the one from Exception.cpp.
committed rev 22709, thanks for the patch!
Campbell Barton (campbellbarton) changed the task status from Unknown Status to Unknown Status.Aug 22 2009, 7:19 PM
