connectors between sensors and controllers and from controllers to actuators doesn't show on Vista
Same blends work on same machine under Karmic
Tested on multiple blends, very consistent, in both OS, multiple machines (office, home)
The connectors work though, and can be taken out (in the new 2.5 manner of reconnecting)
Addendum
Seem to be more specific than first though:
The problem occurs specifically on my laptop
Compaq Presario, CQ70-134CA with
integrated Intel Graphics Media Accelerator 4500MHD
Windows Vista
(probleme does not exist in Ubuntu, on same machine)
There appears to be an issues with smooth line drawing in the windows intel graphics drivers, there is a related bug here in the graph editor:
http://projects.blender.org/tracker/index.php?func=detail&aid=20268&group_id=9&atid=498
Make sure your GMA drivers are the most current.
You can try these links at Intel. The first one should do it
if not. Also I noticed a lot of problems around Intel ogl drivers
and settings set for dual displays on several web sites.
I can duplicate some of your problem with an older driver.
http://www.intel.com/support/graphics/sb/CS-023621.htm
http://www.intel.com/support/graphics/detect.htm
Closing for lack of response, but also since we're pretty sure this is a driver problem and that newer drivers most likely fix the problem.
