Python: accessing ParticleEdit.hair causes segmentation violation #21055
Blender Cloud
Documentation
Eevee & Viewport
Import and Export
Rendering & Cycles
Add-ons (BF-Blender)
Add-ons (Community)
2 Participants
Reference: blender/blender-addons#21055
build 26658
Ubuntu 64 bit
Run the following code.
-------------- Python file -----------
import bpy
ts = bpy.context.tool_settings
print(ts)
pe = ts.particle_edit
print(pe)
for ext in dir(pe):
var = "pe.%s" % ext
print(var)
print(eval(var))
-------- Output ----------
[BPy_StructRNA "ToolSettings"]
[BPy_StructRNA "ParticleEdit"]
pe.BoolProperty
<built-in method BoolProperty of type object at 0x368e120>
pe.BoolVectorProperty
<built-in method BoolVectorProperty of type object at 0x368e120>
pe.CollectionProperty
<built-in method CollectionProperty of type object at 0x368e120>
pe.EnumProperty
<built-in method EnumProperty of type object at 0x368e120>
pe.FloatProperty
<built-in method FloatProperty of type object at 0x368e120>
pe.FloatVectorProperty
<built-in method FloatVectorProperty of type object at 0x368e120>
pe.IntProperty
<built-in method IntProperty of type object at 0x368e120>
pe.IntVectorProperty
<built-in method IntVectorProperty of type object at 0x368e120>
pe.PointerProperty
<built-in method PointerProperty of type object at 0x368e120>
pe.StringProperty
<built-in method StringProperty of type object at 0x368e120>
pe.doc
Properties of particle editing mode.
pe.module
bpy.types
pe.slots
pe.add_interpolate
False
pe.add_keys
5
pe.auto_velocity
False
pe.bl_rna
[BPy_StructRNA "Struct" -> "ParticleEdit"]
pe.brush
None
pe.draw_particles
False
pe.draw_step
0
pe.editable
False
pe.emitter_deflect
True
pe.emitter_distance
0.25
pe.fade_frames
0
pe.fade_time
False
pe.hair
Segmentation fault
%%%Could someone else try this?
Im enable to redo this crash...
no errors while using valgrind which normally will detect problems like this.%%%
%%%unable to redo the crash*, tested on 64bit ubuntu karmic.%%%
%%%was testing with a particle system where it didn't crash.
fixed in svn, thanks for the report.%%%
