Add rotate option to blf module #21867
Blender Cloud
Documentation
Eevee & Viewport
Import and Export
Rendering & Cycles
Add-ons (BF-Blender)
Add-ons (Community)
Reference: blender/blender-addons#21867
%%%Added an optional angle argument to the blf.draw function to allow the text to be rotated.
I tried to wrap the BLF_default_rotation directly but it sets the global text rotation angle and if you don't reset it then... well, not really intended behavior results.
So this patch sets the angle, calls the draw function and then resets the rotation angle back to 0 which is a lot safer than the alternative.%%%
%%%Version #2 with wrappers for rotate, shadow and clipping along with the helper functions to get them to work.
No idea what BLF_KERNING_DEFAULT does but threw that in as well for completeness.%%%
%%%Could you please make these 2 changes.
%%%Ok, did #1, if blur != 0, 3 or 5 it throws an error.
On change #2, this would break consistency with the bgl module where all the constants are in the same flat namespace as the functions.
And, as we all know, Consistency is King...
Based on my own usage of this module the chances are good that the user will also be using the bgl module as well and will expect them to behave similarly when it comes to constants since they both fulfill a nearly identical roll.
Having different methods for the same thing like bgl.glEnable(bgl.GL_BLEND) and blf.enable(blf.modes.ROTATION) will just lead to confusion IMHO.
I did however remove the BLF_ prefix as per your request since blf.ROTATION is pretty nearly the same thing.%%%
%%%applied patch to trunk, /w small fix, exception needed to return NULL, not -1.
re: opengl consistency, we have a number of python api's so its a choice to which once you want to match, but since this is probably used with OpenGL I can see the rationale. %%%
%%%This might come a liitle late, but I just noticed, that the "invalid blur level" error doesn't show up when using blf.blur() inside the Game Engine.%%%
