3D View: multiselect menu
Closed, InvalidPublic
Project: Blender Extensions
Tracker: Py Scripts Contrib
Blender: 2.61
Author(s): Sean Olson (liquidApe)
Script name: space_view3d_multiselect_menu
Homepage: pending
Wiki page: ?
Category: 3D View
SVN Download: https://svn.blender.org/svnroot/bf-extensions/contrib/py/scripts/addons/space_view3d_multiselect_menu.py
Status: Open
Related: 22060
Adds selection combination's to the multi select menu
merged into dynamic spacebar menu, edit mode, multi select.
closed.
Updated multiselect menu to work with 2.56 (tested with v. 34488)
hey sean,
are you aware that this script has been merged into http://projects.blender.org/tracker/index.php?func=detail&aid=22060 ?
I see that you don't have svn rights so if you feel you want to maintain that script, you can:
1) attach patches there
2) ask for svn rights to maintain your part, we can discuss this in #blenderpython on freenode
thanks!
Hi Luca,
Yes, I'm aware that the script was merged and that makes me happy that others are getting use of my code. I'd rather not have the responsibility of watching part of another add-on though! Truth be told, I usually ponder over the Dynamic spacebar addon to figure out what changed in the api in order to update this one. I personally like this one as it's much lighter than dynamic spacebar. I'll talk to you on freenode next time I see you.
updated to work with key-bindings other than the default setup.
moved back to contrib svn, sorry for delays.
Sean Olson needs svn access.
I'm happy to maintain until then.
This script was merged with the spacebar menu but still has usefulness as a standalone.
This script is currently broken and is unable to be installed.
I'm using 2.62 RC1 r43946
Thanks for looking :)
hi, please get thescript from the svn link.
removed attatchments
Hi,
Due to changes to the api including the merging of bmesh, several addons are outdated.
Please, if you are the author of an addon check your script with blender revision 44256 or newer.
That is builds made After blender 2.62 official release.
I would ask that updates be made to your addon before the Blender 2.63 release.
6-8 weeks away.
This allows time for the api to become more exposed & bmesh to stablize furthur.
If you need help, drop into irc freenode #blenderpython or #blendercoders & feel welcome to ask questions.
At the time of 2.63 release, scripts that are not repaired or in active developement will have their tracker page marked "Closed"
this will not affect your links to the tracker, similar to closing scripts in 2.49b, the page will be still availible & can be re-opened.
Thanks for your understanding & patience during these Exciting Times.
Brendon.
This task was automatically closed as archived as part of migration, because it was determined to be no longer active.
The authoritative list of addons is on the wiki, we no longer have a report for each addon to track bugs and updates. Bugs can be reported individually and assigned to the addon developers. See the Add-ons (Community) project page for more information on the workflow.
Nobody (None) changed the task status from Unknown Status to Unknown Status.Apr 23 2010, 3:31 AM
