3d View: Simple Align #22389
Blender Cloud
Documentation
Eevee & Viewport
Import and Export
Rendering & Cycles
Add-ons (BF-Blender)
Add-ons (Community)
8 Participants
Reference: blender/blender-addons#22389
Project: Blender Extensions
Tracker: Py Scripts Contrib
Python: 3.2
Blender: 2.61
Author(s): Gabriel Beaudin (gabhead)
Script name: 3D View: Simple Align
Wiki page: http://wiki.blender.org/index.php/Extensions:2.5/Py/Scripts/3D_interaction/Align_tools
Category: 3D View
SVN Download: https://svn.blender.org/svnroot/bf-extensions/contrib/py/scripts/addons/space_view3d_simple_align.py
Status: Open
%%%Add align tools to the 3d_view toolBar(at left).
All selected objects are align to the active object.
This task was automatically closed as archived as part of migration, because it was determined to be no longer active.
The authoritative list of addons is on the wiki, we no longer have a report for each addon to track bugs and updates. Bugs can be reported individually and assigned to the addon developers. See the #Addons project page for more information on the workflow.
%%%moved this handy tool to release.%%%
%%%*Fixed a bug with the scales operators.
I was trying to chance "S"cale propretie while the actual propretie is "s"cale. ^_^
%%%*Changed the code to have only on operator.
*Changed Buttons for checkboxs.
This version don't support edit mode yet.
%%%*BugFix%%%
%%%*BugFix%%%
%%%v0.8
todo:
support edit mode
support parenting
support pose mode%%%
%%%v.0.9
%%%v0.10
%%%I uploaded the pyc file last time...sorry.
%%%V 0.10%%%
%%%V0.11
%%%BugFix:
%%%V0.13
BugFix
%%%hi, sorry about the mismatched version in trunk.
could you please download the script from svn first
https://svn.blender.org/svnroot/bf-extensions/trunk/py/scripts/addons/space_view3d_align_tools.py
then if you could apply all your changes the script will be up to date & I'll add to trunk.
if you can get onto irc freenode #blenderpython, I can help with preventing this version mismatch in the future.
Thanks.%%%
tested on api: 32121
svnrev:1083%%%
%%%hi,
the script I have is the current working version. rev 32121
Any additions should be made to this file,
the code has been cleaned up & fixed for api changes.
please add extra buttons & functions using the methods in this version before any changes to our svn.
Thanks.%%%
%%%working revision update
rev: 32411%%%
%%%assigning to gabriel%%%
%%%Hi!
Since your script is now in bf-extensions' svn (contrib|trunk) we have deleted the current attachments to avoid that end-users could reach this page and get the wrong version of your script.
Note that your script may have api changes or small maintenence changes applied in SVN.
Please retrieve your script from SVN before updating SVN to avoid mis-versioned scripts.
Thanks!
%%%Moving "Align Tools" addon from trunk to contrib. This addon is conflicting with the inbuilt Align Objects operator (register name conflict). Furthermore This is not an alignment tool, it's a copy transformation tool so I'd suggest to rename it. Also link to tracker in the addon is wrong%%%
%%%Moved from Py Scripts Release to Py Scripts Contrib%%%
%%%moved tracker page to contrib%%%
%%%I agree with Daniel Salazar. It would be better to rename the script.
When I copy rotation or scaling with the script buttons and then, use an operator (without deselecting like adding a sphere) and change a setting in last operator panel : previous action of the script is cancelled.
%%%rename to simple align, updated in svn
thanks & sorry for the delay.%%%
%%%Hi,
Due to changes to the api including the merging of bmesh, several addons are outdated.
Please, if you are the author of an addon check your script with blender revision 44256 or newer.
That is builds made After blender 2.62 official release.
I would ask that updates be made to your addon before the Blender 2.63 release.
6-8 weeks away.
This allows time for the api to become more exposed & bmesh to stablize furthur.
If you need help, drop into irc freenode #blenderpython or #blendercoders & feel welcome to ask questions.
At the time of 2.63 release, scripts that are not repaired or in active developement will have their tracker page marked "Closed"
this will not affect your links to the tracker, similar to closing scripts in 2.49b, the page will be still availible & can be re-opened.
Thanks for your understanding & patience during these Exciting Times.
Brendon.%%%
Added subscriber: @FilipMond
just to be sure … wiki says script is version "0.11", but what I see at script it's verson "0.1".
Maybe only one number extra on wiki?
Reason why I'm asking is differences on UI on wiki and in blender.
(left wiki, right blender)
Right image seems like last version.
On left image it seems like script was able align not only origins?
Added subscriber: @jacky3horn
Hi is it possible to deactivate the mouse crosshair ruler but let the upper ruler (yellow ) sustain..?!
that woulld be great ..
best regrd Sebastian R.
