Export: Quake MD3 #23160
Blender Cloud
Documentation
Eevee & Viewport
Import and Export
Rendering & Cycles
Add-ons (BF-Blender)
Add-ons (Community)
5 Participants
Reference: blender/blender-addons#23160
Project: Blender Extensions
Tracker: Py Scripts Contrib
Blender: 2.54
Author(s): Xembie
Script name: Export: Quake MD3
Homepage: http://xembie.com/2010/md3-exporter/
Wiki page: ?
Category: Import Export
Status: No wiki
%%%Exports the Quake Model 3 format from selected mesh objects.
This task was automatically closed as archived as part of migration, because it was determined to be no longer active.
The authoritative list of addons is on the wiki, we no longer have a report for each addon to track bugs and updates. Bugs can be reported individually and assigned to the addon developers. See the #Addons project page for more information on the workflow.
%%%Requires mesh to be made of triangles.%%%
%%%moved to contrib, will further test a move to svn shortly%%%
%%%[canned response]
Hi, can you prepare a wiki page with a bit of a manual about how to
use this?
See
http://wiki.blender.org/index.php/Dev:2.5/Py/Scripts/Guidelines/Addons
Thanks!%%%
%%%fix for API changes.
http://www.pasteall.org/18286/diff%%%
%%%Hi!
Since your script is now in bf-extensions' svn (contrib|trunk) we have deleted the current attachments to avoid that end-users could reach this page and get the wrong version of your script.
Note that your script may have api changes or small maintenence changes applied in SVN.
Please retrieve your script from SVN before updating SVN to avoid mis-versioned scripts.
Thanks!%%%
%%%Hi,
Due to changes to the api including the merging of bmesh, several addons are outdated.
Please, if you are the author of an addon check your script with blender revision 44256 or newer.
That is builds made After blender 2.62 official release.
I would ask that updates be made to your addon before the Blender 2.63 release.
6-8 weeks away.
This allows time for the api to become more exposed & bmesh to stablize furthur.
If you need help, drop into irc freenode #blenderpython or #blendercoders & feel welcome to ask questions.
At the time of 2.63 release, scripts that are not repaired or in active developement will have their tracker page marked "Closed"
this will not affect your links to the tracker, similar to closing scripts in 2.49b, the page will be still availible & can be re-opened.
Thanks for your understanding & patience during these Exciting Times.
Brendon.%%%
