Python can't handle German umlaut characters in strings #23197
5 Participants
Reference: blender/blender#23197
%%%The Blender UI lets you enter the German Umlaut characters ü, Ü, ö, Ö, ä, Ä and ß. However strings containing them cause exceptions whenever Python scripts try to work with them. This is probably a more general problem, but I got it with Umlauts.
Steps to reproduction:
You should get the following output in the Blender console window:
UnicodeDecodeError: 'utf8' codec can't decode byte 0xfc in position 0: unexpected end of data
The cause is that the script tries to print the name of the cube mesh and this name is "ü".
System:
%%%Sorry, I placed this in the wrong tracker. Of course it belongs into the Blender 2.5 Bug Tracker.%%%
%%%Closed duplicate report:
http://projects.blender.org/tracker/index.php?func=detail&aid=23424&group_id=9&atid=498%%%
%%%fixed r31655.%%%
Added subscriber: @JamesCrowther
Changed status from 'Resolved' to: 'Open'
Hi guys, using current release (see system info here-> system-info.txt) blender 2.78c on Macosx 10.12 and believe this issue has returned as far as the title is concerned, attempting to access materials from the python console that have names containing umlauts causes errors, for example
Using this blend file from blendswap -> http://www.blendswap.com/blends/view/2259
Trying to access the materials from the python console window in blender like so...
Also, when recursively printing all the materials in the console...
and lastly, i am running a the following code block in the python console which uses the python builtin 'hasattr', when it encounters materials whose names contain umlauts an error is thrown ...
@JamesCrowther, this is a different issue to the original report.
The problem is that existing files may have non-UTF8 names which we don't support anymore.
To solve this we would need to rename id-names on loading files, but thats quite error prone too.
(would need to check new-name is unique, might break library linking).
@ideasman42 , different issue - no problem. Just seemed close enough to warrant re-opening this one rather than creating a whole new bug report.
Will this affect the ability to open old files in future versions? Its been a long standing feature of blender to be able to open old files with practically any version of blender and (mostly) the file opens ok.
Is there a way to avoid this error in python somehow? In many cases, I've used hasattr to make sure an attribute I am going to access exists so I don't cause an error. I suppose one way to avoid it might be to revert to try/except?
But, in that case, what remedial action can a script take? Changing the name is one approach I guess we could take, but as you said, this might cause errors downstream.
Any ideas?
Added subscriber: @mont29
Yes, Blender tries to keep backward compatibility as much as possible - but we cannot address all (corner)cases, even less when we are talking about 8 years old files…
Also here file is not actually broken, it’s access from py API which becomes problematic. You most likely can work something around, Python's encoding module is quite powerful and flexible, you can also control how encoding errors are handled, etc.
Thanks for the report, but this is more like support request for an old broken corner case, not a bug anyway.
Posted solution to update your files: https://blender.stackexchange.com/questions/78931
