Drivers not working and some not appearing in Drivers editor
Closed, InvalidPublic
I found some problems with drivers on certain data.
Trying to add driver to texture x and/or y offset creates no driver but does not animate if keyframe is added manually.
Trying to add drivers to anything in the material node editor does not create a driver. These values are also not possible to animate by adding keyframes maually.
Ubuntu 10.04 64bit
Blender 2.53 svn r31458 linux 64bit (graphicall.org)
Workaround :
The Texture Driver appears in the editor if you add a Material Driver on the object.
I hope this will help targeting the bug :).
This is something for todo. Dependency graph needs to be redesigned for this. Moving to todo wiki: http://wiki.blender.org/index.php/Dev:2.5/Source/Development/Todo/UserInterface#Dependency_Graph
